Author Topic: CUB Pro-101 TPMS (learn/set) tool on clearance at Tire Rack  (Read 23471 times)
Re: CUB Pro-101 TPMS (learn/set) tool on clearance at Tire Rack
« Reply #25 on: August 07, 2014, 11:54:02 AM »
Tried to read the TPMS and although it took likely 20 seconds to read it, it did read on the Volt, once. Can't get it to read again but it reads almost instantly on the Solstice.
Have to play around with it a bit more when the batteries have a chance to fully charge.
Regardless it was worth it even if I can't get it to work reliably with the Volt and yeah I know, you told me so.
« Reply #26 on: August 09, 2014, 05:04:09 PM »
As I said I've been away, so got to open the box today.  After three hours charging (not really enough, so it's back charging now) I tried it out and it works like a champ! Programmed all my sensors - which had been partially mucked up the last time at the dealer. I had tried the pressure up/down method before, but could never get it to work. This is SO, SO, much easier.
Quick tip: when setting the vehicle type on the tool, use the "up" button to select both Pontiac and then Solstice, since they're down near the bottom of the lists. Ditto Saturn and Sky :)
Offline SKY_RL_Qc
« Reply #27 on: August 14, 2014, 01:09:33 PM »
For those who want to upgrade the tool.
http://cubelec.com.tw/guide.php
2008 Sky Red Line Bluestone/Black
« Reply #28 on: August 14, 2014, 06:24:57 PM »
Has anyone upgraded theirs yet?
« Reply #29 on: August 14, 2014, 07:13:10 PM »
I went to the site, but you have to login with a user/password.  May only be for dealers :huh:
« Reply #30 on: August 14, 2014, 08:01:30 PM »
try calling and asking what you need to do:
Tel: 886-4-778-2010, 777-0256
 Fax: 886-4-778-2009, 778-3867
Offline username
« Reply #31 on: August 14, 2014, 10:59:02 PM »
If someone gets the update software, could you post it up on one of the various sharing sites?
Offline Wartie
« Reply #32 on: May 28, 2018, 09:07:13 PM »
Just curious, I tried using my PRO-101 today and it will not stay powered up (even with new batteries) long enough to get through all 4 wheels. Anybody else experience this? It was a good deal but I would have liked to be able to use it more than a couple of times.
« Reply #33 on: May 29, 2018, 12:35:07 AM »
No issues here with mine Bob.  Worked fine a few months ago when I last used it although I find I have
 to use it fully charged.
Offline Wartie
« Reply #34 on: May 29, 2018, 01:13:42 PM »
I have been charging it for two days. Oh well.
« Reply #35 on: May 29, 2018, 01:45:34 PM »
Are you trying to use that on the S10?
« Reply #36 on: May 29, 2018, 03:53:47 PM »
Hahahahaha
Offline Wartie
« Reply #37 on: May 30, 2018, 06:06:48 AM »
What it won't go back that far?  :idk:
It came back again for another bleeding of the clutch master cylinder. The pedal is up where it should be now. My father in-law's 86th birthday is Friday. I didn't tell him but I moved the seat up about an inch to help him get the pedal to the correct position.
 I also put new tailgate hinges on it so he does have to use a piece of wood to get it to shut. On a side not he bought red duct tape to fix some rust.   :buff:
« Reply #38 on: May 30, 2018, 01:11:59 PM »
Did Critter help you with this post?
Offline Wartie
« Reply #39 on: May 30, 2018, 02:19:53 PM »
No I f'd it up all on my own!!!! I am approaching his age though.  :devil:
« Reply #40 on: May 30, 2018, 03:33:36 PM »
45?
« Reply #41 on: May 30, 2018, 03:33:55 PM »
You better pedal harder.  You have a way to go.
SA - FU
« Reply #42 on: May 31, 2018, 08:44:49 AM »
SA - FU
Ahh... A graduate of the Oscar Wilde School of Wit and Repartee!
« Reply #43 on: May 31, 2018, 11:10:14 AM »
Why is he calling me Felix Unger?
« Reply #44 on: May 31, 2018, 12:39:04 PM »
:rofl: :rofl: :rofl:
