Yes, it will bolt right up. We have done this several times, works pretty good. You can use the stock LNF oil supply line and the stock water supply line if you modify the thermostat housing on the 2.4L. The other option is to get a LNF thermostat housing which already is tapped for the water supply. For the oil return, you can drill the pan in the exact location that the LNF uses and use a stock drain, or typically we return the oil into the plate that is access for the water pump on the front of the engine. For the water return, you can make a tube to return it into the upper radiator hose easily. Then the turbo will mount right up and you can use a stock intake and any downpipe that fits a LNF and it will bolt right up to the exhaust.
Hope that helps,
Dave
