Author Topic: WERKSracing 9/3/14 New Product Releases!!!  (Read 4108 times)
« on: September 03, 2014, 03:16:47 PM »
Here are a few items we have been working on for some time now and are just getting around to officially releasing them online.  :tool:
WERKSracing 9/3/14 New Product Releases -
1) WERKSracing Kappa Adjustable Clutch Master Cylinder
Developed to solve the dreaded clutch adjustability and bleed issues found in the Kappa platform when installing aftermarket clutches, our re-worked OEM adjustable clutch master cylinder adds up to 5mm of extra stroke and allows the end user to properly adjust clutch engagement without having to pull the transmission back out to shim the clutch slave cylinder found inside the bellhousing.
Features -
New OEM clutch master cylinder
5mm added stroke
Adjustable metal clevis linkage
1 year warranty
We can also modify your OEM clutch master cylinder to these specs for $200.00 if you send it into us.
Order here for $299.99 - WERKSracing Kappa Adjustable Clutch Master Cylinder
2) WERKSracing LNF/LDK/LHU Aluminum Intake Manifold Flange
Features -
1/2" Thick 6061 Aluminum to prevent warping
Water jet cut
Machined recess for proper PCV fitment
Order here for $99.99 - WERKSracing LNF/LDK/LHU Aluminum Intake Manifold Flange
3) WERKSracing Kappa/LSx Motor and Transmission Mount Kit
Our WERKSracing Kappa/LSx Motor and Transmission Mount kit is now available online. This custom in-house manufactured kit is the same kit that we use on our in-house Kappa/LSx V8 conversions.
This kti allows the end user to mount any LSx based engine block and a T-56 6 speed manual transmission into the Kappa chassis without chassis modifications.
Features -
Hand TIG welded steel engine mounting brackets with OEM GM mounts.
CNC cut and hand TIG welded 6061 aluminum Transmission cradle bracket
Polyurethane transmission mount
Comes complete with all mounting hardware and instructions
Automatic Transmission kit will be released shortly...
Order here for $675.00 - WERKSracing Kappa/LSx Motor and Transmission Mount Kit
« Last Edit: September 11, 2014, 02:44:57 PM by werks »
Re: WERKSracing 9/3/14 New Product Releases!!!
« Reply #1 on: September 03, 2014, 06:28:21 PM »
Lotta-stuff
« Reply #2 on: September 04, 2014, 10:16:54 AM »
This is just the beginning... :)
If I actually had the time and the moolah to execute all of the idears in my head you guys would be overdosing on shiny shit :)
« Reply #3 on: September 04, 2014, 11:08:50 AM »
You can overdose on Shiny's shit?  GJ, Reed, Critter did you know this?  Where is Shiny anyway?
« Reply #4 on: September 05, 2014, 02:42:14 PM »
You can OD on any shit!
Offline spartan
« Reply #5 on: September 05, 2014, 08:50:34 PM »
Dave,
   On the flange, please explain the advantages.  Also, do your phenolic spacers work with this flange?  Thanks.
« Reply #6 on: September 08, 2014, 10:29:30 AM »
Dave,
The .5" thick 6061 aluminum intake manifold flange is specifically for those who wish to fabricate their own custom sheet aluminum intake manifold.  It is the same one we now use to construct our Kappa sheet aluminum intake manifold - http://www.performanceautowerks.com/catalog/product_info.php?products_id=2017
Yes, our phenolic spacers will work with this flange.
Offline cdnite
« Reply #7 on: September 09, 2014, 04:27:26 PM »
Is your estimated shipping time still 10 months or has it improved since the swaybar deal?
Also I have an issue with the locking collars for my sway bars. I would love to receive a call from you guys!
--Christian
« Reply #8 on: September 09, 2014, 04:32:10 PM »
--Christian
CHRISTIAN,
Definitely not 10 weeks for these items :)  I am in a Sky Redline right now tuning an automatic transmission shift parameters, what is the issue with your locking collars on your sway bars?
