Author Topic: DC front strut bar  (Read 45606 times)
Re: DC front strut bar
« Reply #75 on: August 31, 2015, 01:26:40 AM »
Hmmm
Strange the equivalent 15# drop.
Almost enough to start checking things.
Offline Napi
« Reply #76 on: August 31, 2015, 04:26:33 AM »
I have the compression checked regularly, when I change the spark plugs. (every 20k km)
The drop from cylinder 2 to 3 was always around 0.4bar(~12psi).
The decrease over the last three years was about 0.2bar (6psi) in average. Ok, I guess. :cool:
But I thought it is "common" with LNF-engines to drop on cylinders 3&4...
« Reply #77 on: September 01, 2015, 12:43:43 AM »
I always thought 1&2 were commonly the issue.
Others??
Offline Napi
« Reply #78 on: September 01, 2015, 01:25:50 AM »
Hmm.
I guess, the "rear cylinders" have to withstand more heat, caused by the engines position in the bay and thereby in the air flow...
Anyways, a buddy suggested to check the timing chains, as the ones on his GT emmitted comparable noises when they were stretched...
The shop will check them this weekend...
« Reply #79 on: September 01, 2015, 03:59:49 AM »
Number #1 cylinder is the farthest one, it fails most often when is about fuel starvation.
In my case #2 and #3 failed but because of high revving, oiling aspects generated possibly by track driving.
Offline Napi
« Reply #80 on: October 02, 2015, 02:38:53 AM »
Guess what:
The Vibration is gone.
Obviously, the vibration came from a damaged Timing chain tensioner.
I had both chains plus accessories including all belts and the water pump renewed at a local Opel Garage and the Vibration is gone. Entirely.
The brace is now equipped with two Aluminium plates on the downfacing bracket, 3mm each, and will be re-installed this Weekend. Hopefully, this will not cause any new Problems. :cool:
« Reply #81 on: October 02, 2015, 04:24:28 PM »
Good to hear you found the issue.
Offline Napi
« Reply #82 on: October 03, 2015, 01:02:15 AM »
Aye!
The cool thing is, it was the brace that made me check the entire engine an check every single sound... Otherwise I would possibly not have noticed the damaged tensioner which, following the shop, would have failed completely in short time... :barf:
« Reply #83 on: October 06, 2015, 12:54:55 PM »
How much for the parts?
Offline Napi
« Reply #84 on: October 06, 2015, 01:46:17 PM »
Around 900 Euros...
« Reply #85 on: October 06, 2015, 03:55:35 PM »
Damn, ty for info ;)
