Author Topic: WERKSracing LNF Kappa intake manifolds in stock ready to ship!!!  (Read 5490 times)
« on: September 10, 2015, 02:51:57 PM »
We have a couple WERKSracing LNF Kappa aluminum intake manifolds in stock and ready to ship!!!  This is a rare occurrence here as you know we mostly built our stuff to order so get these while they are available!!!  :yay:
1 - Satin Black
1 - Uncoated, ready to be powdercoated in the color of your choice!
Available here for $899.99 - WERKSracing LNF Kappa aluminum intake manifold
Offline cdflint
Re: WERKSracing LNF Kappa intake manifolds in stock ready to ship!!!
« Reply #1 on: September 10, 2015, 10:26:56 PM »
That does look purty.
She's an 09 Brazen GXP.
« Reply #2 on: September 11, 2015, 10:49:15 AM »
What does this do?
« Reply #3 on: September 11, 2015, 11:03:25 AM »
What does this do?
You mean besides removing $900 plus shipping from your wallet?
« Reply #4 on: September 11, 2015, 06:59:50 PM »
For the consumer, what is the benefit of this product over the stock manifold?
« Reply #5 on: September 11, 2015, 10:46:03 PM »
If i woukd have to guess if your stock NO BENEFIT
If your talkng EVERYTHING stock WHICH MEANS NO TUNE the ECM limits EVERYTHING so no BENEFIT.
Though not everyone does things for a performance benefit either so maybe a asthetic benefit though i woukd be hard pressed to spend $900 bones for one piece of bling under the hood but peeps have done stranger things.
Bigger turbo and supporting mods the mani helps but its all what you want to do and have tje $$ for.
Though at some point id look at it and say LS swap would be better.  If i still had my Sol i would have liked to do an LS swap but now ive got a Camaro Ss that down the line ill Supercharge it.
4 banger fun 8 banger MORE FUN IMO.
« Reply #6 on: September 11, 2015, 11:28:50 PM »
I have Meth, A fully built engine [Top and Bottom] and an EFR 6758
So I am curious, what would this product allow someone with my build to do?
Offline VinnieRL
« Reply #7 on: September 12, 2015, 05:03:09 PM »
"Does not come with new driver's side IC pipe, new driver's side IC piping will have to be fabricated."
Just a heads up before you order.
DDM I/C Pipes, OCC, Shifter, Adapter & Boot, Silicone Hoses, T-Bolts, trunk & hood lights
Werks I/C, Radiator, Backbone & Swaybars
reBar
K&N CAI
MF Catback
Solo Race Pipe
3bar MAP w/ ZZP Tune
Windrestrictor & Lit Sills
Heated Seat
Quaife
Offline hammy221
« Reply #8 on: September 13, 2015, 09:54:44 AM »
I'm only gassing but I'm thinking its to handle high boost pressures or give the same effect as a high rise manifold
« Reply #9 on: September 13, 2015, 12:28:41 PM »
To the vendor:
I've checked out your website.
Can you explain how this improves the stock set up when using larger turbos?
What is the restrictions in the stock unit that you have solved here?
« Reply #10 on: September 14, 2015, 11:47:34 AM »
To the vendor:
The larger intake plenum and longer runners give the ability to "store" and deliver greater amounts of air versus the stock intake manifold.  In addition the ability to "store" air inside the larger plenum along with larger runners keeps the intake charge cooler versus stock .  The benefits are better realized with larger turbocharger that can feed greater amounts of cooler air into the plenum.  We also have the ability to flange these units for larger throttle bodies.
