Author Topic: 1 year on the replacement motor  (Read 4488 times)
Offline Rogue
« on: October 22, 2015, 07:53:56 AM »
It's now been about a year since we replaced the motor in GXPsy. That was a pretty painful experience, but we've gotten over that part of it. We purchased a complete crate unit from ZZPerformance, and had a few install issues to resolve. Now we're glad we did. Oil pan interference, heater hose/cylinder head configuration, etc. The end result has been worth it. Our local GM dealer did the work for us, and in the process identified the engine as one of a special build for the high performance HHR. I do not know what the exact differences are internally, however the power is obviously higher than the original LNF (with GMPP tune) and the average fuel economy is at least 2 mpg better than before. Woohoo. More power, less fuel. The Mrs just loves blowing the unsuspecting rice rockets into the weeds!
Go N.A.K.3.D..
Offline Johnny_gxp
  • Quick Shifter
Re: 1 year on the replacement motor
« Reply #1 on: October 22, 2015, 09:06:39 AM »
Glad to hear it! I don't get to surprise people anymore  :( my car is too flashy now. Also, I do believe the HHR SS still made 260/260 unless of course it was just another GM hush hush like the old LS1 trams am. (States 325hp made 350ish)
Aggressive '08 Solstice GXP
« Reply #2 on: October 22, 2015, 04:49:16 PM »
Glad the swap worked out well. If I lost mine I do know which way I'd turn. Maybe a V8 swap but I don't know...
Offline Rogue
« Reply #3 on: October 22, 2015, 05:44:56 PM »
I don't know what the difference is either, but it obviously makes a lot more power, the torque curve is fatter, and the fuel economy is higher. A total win for us. If anyone has any insight kindly share it.
Go N.A.K.3.D..
Offline JesseB
« Reply #4 on: October 22, 2015, 09:28:26 PM »
Sounds to me like you ordered the LDK long block from them?
Offline Rogue
« Reply #5 on: October 23, 2015, 06:52:28 AM »
I believe that is correct. Then we swapped out the LNF cylinder head and oil pan.
Go N.A.K.3.D..
« Reply #6 on: October 23, 2015, 11:01:40 AM »
The noticeable change in performance could be due to the decline in performance of the old engine before it died or the fact that the old engine had a problem from the start.
Offline Rogue
« Reply #7 on: October 23, 2015, 11:48:40 AM »
We have considered that. But, don't believe that to be the case based on performance comparisons to my GXP.
Go N.A.K.3.D..
« Reply #8 on: October 23, 2015, 12:47:11 PM »
The only difference I could think of would be internal friction.  That could increase mileage, but I wouldn't think it would increase power on a turbo car (presupposing the same turbo and tune).
Offline roxer
« Reply #9 on: October 23, 2015, 09:23:35 PM »
Think I read where the LDK produces about 10 more hp than the LNF.
Offline Rogue
« Reply #10 on: October 24, 2015, 08:49:56 AM »
I have heard some rumors (do not recall where) that the LDK compression is a bit higher. However, my first instinct was to think it might be a different cam profile. This motor seems to be more friendly to the automatic transmission.
Or, maybe it's all just our imagination.
Go N.A.K.3.D..
Offline Johnny_gxp
  • Quick Shifter
« Reply #11 on: October 24, 2015, 10:17:54 AM »
I read
LDK: 9.3:1, higher compression Pistons.
LNF: 9.2:1, and our normal piston head
That would be your extra 10 right there. But with that slight increase in compression to boost: that's a sure fire way to increase your numbers throughout the torque curve.
Offline Rogue
« Reply #12 on: October 24, 2015, 03:38:45 PM »
Higher compression pistons would most definitely produce better power, torque, and economy figures. Especially coupled with the boost effects of a turbo.
Go N.A.K.3.D..
Offline Rogue
« Reply #13 on: October 24, 2015, 03:39:42 PM »
Johnny_gxp - That's interesting info. Where did you source it?
Go N.A.K.3.D..
