Author Topic: Is a 19x9.5 with +30 offset and 275 tires on all 4 corners out of the question?  (Read 6061 times)
Offline JesseB
Will it fit & work on all 4 corners without modification?
Offline Gabes Redline
Those measurements will cause the wheel to stick out of wheel well.
Offline JesseB
Rears or fronts? or both? Any idea how much it will stick out?
Offline DaveOC
  • Running Wisconsin
If the math I just did in my head is correct, they will stick out almost 2 inches more than the stock wheels/tires at each wheel.
Aggressive #000741
The fronts are not necessary.
My rears are 18x9's +55mm offset and they fit just fine.
Offline JesseB
what do you mean not necessary? I dont know much about this stuff
The front 245s work fine for traction and a staggered setup works well with handling
Offline JesseB
Wouldnt 245s be a little small on a 9.5" rim? Probably be more likely to dent the wheel wouldnt it? ....I found a +40 offset for 9.5, that would help a bit...I have been in a friends truck whose tires rubbed really hard on turns, thats what im trying to avoid. Just making sure that I am in the clear*on all 4 corners* with a 9.5"  with 275 tires and now a +40 offset
Yes
Stick with 8" wide rims up front with the stock tire size.
Offline hippo
It will work but not without its drawbacks. I currently run 18x9.5 +35 on my sky with 265 width tires and while they do fit, a bit of fender rolling/ stretching had to be done on the rear along with 2+ degrees of camber all the way around. The biggest problem is found was that I could not run as much caster as I would like because the tire would rub the inner liner on the front during hard cornering.
Offline JesseB
ok, say I found a 9.5 in +40 offset, would this be enough that no modifications would be needed? (fender rolling and camber adjustments...etc) I am at stock ride height.
Elf, I would rather have them all the same for tire rotations and such, ive read goods and bads of staggered setups and just dont really know where I stand....but...they do offer the wheels im looking at in 19x8.5 with offsets of 42, 30, 45 ...which would match best with my 19x9.5 offset 40?
edit: everything I have read is saying that there is actually more room in the front? so if it fits in the rear, it will fit in the front...is this correct?
« Last Edit: January 04, 2016, 07:40:59 PM by JesseB »
IMHO the only downside is the inability to rotate the tires.
For me, that doesn't matter.
A lot of car companies sell staggered setups.
