Author Topic: TCE Big Brake kits  (Read 3170 times)
Offline username
TCE Big Brake kits
« on: September 16, 2016, 02:38:10 PM »
Installed this a few months back after my wheel hub bolts backed out during an event, destroying a stock rotor. (Otherwise, upgraded pads would have been more than enough to go racing with.) I made the mistake of only visually inspecting the hub bolts every event, instead of verifying the torque before each time.
Kit fits great, came with all required hardware, saves a bunch of weight versus the stock brake setup and was REALLY cheap for a BBC with top-end components.
Went with the 13" front kit and the 12.3" rear kit. Much cheaper than the alternatives ($700+ per end of the car), and unlike Rotora stuff, there's lots of options for pads for the standard Wilwood calipers, as well as the rotors, so you're not locked into a single vendor or limited compound options.
Re: TCE Big Brake kits
« Reply #1 on: September 16, 2016, 07:59:26 PM »
I have been running a similar setup for years.
Todd @ TCE is awesome and has excellent customer support
Offline username
« Reply #2 on: September 19, 2016, 02:45:47 PM »
Yup, for less money, you get a better setup with fantastic support.
« Reply #3 on: September 19, 2016, 05:55:27 PM »
Yea, I was looking at some of the recently advertised setup and saw that they were at least 2x the cost, if not more
