Author Topic: Installed ddm works header and car is way to loud now  (Read 11817 times)
Offline hammy221
« on: October 10, 2016, 11:12:29 PM »
So I installed a ddm long tube header. Car has a stage 2 supercharger magnaflow 2.5" exhaust with no cat. Before the header was installed I loved the sound and the only difference then and now is it had the factory header with a hollowed out factory cat. My question is has anyone else experienced this and If so how did you tame it. I'm thinking installing a cat might do the trick. Any input  would be appreciated.
Re: Installed ddm works header and car is way to loud now
« Reply #1 on: October 10, 2016, 11:41:53 PM »
I had the exact same problem when I installed it. I ended up talking to Solo Performance and got a muffler that I then welded into the center tunnel area.
Offline hammy221
« Reply #2 on: October 11, 2016, 09:52:40 AM »
How much did it help
Sent from my iPhone using Tapatalk
« Reply #3 on: October 11, 2016, 12:51:20 PM »
It calmed it down quite a bit. I also had a CAT. There was still a tolerable drone in the cab of the car even while cruising at a steady speed. I'm not sure how loud/ not loud your car was before the header. So, it's kinda hard to tell if you will get the same results. My exhaust was the RPi GT setup.
Offline username
« Reply #4 on: October 11, 2016, 03:37:57 PM »
Why don't you just install a catalytic converter, which won't cause any power loss, dramatically improves the emissions of your car AND will act as a muffler?
« Reply #5 on: October 11, 2016, 04:09:46 PM »
just install a catalytic converter, which won't cause any power loss...
Many dyno graphs/ pulls with and without CATS say otherwise.
IMO, since I myself had the stage 3 SC and the LT header, a CAT alone will not quiet down Hammy's exhaust enough. Been there. Done that.
Offline hammy221
« Reply #6 on: October 11, 2016, 11:11:08 PM »
Ya I think I'll need solo  quiet exhaust   Version rather good resonator to it
« Reply #7 on: October 11, 2016, 11:36:31 PM »
Did Critter type that for you?
« Reply #8 on: October 12, 2016, 12:19:51 AM »
Put a cat back in.
Stop killing bees, quiet down your noisemaker, make the world happy and drive fast!
Offline Wartie
« Reply #9 on: October 12, 2016, 06:07:47 AM »
Put a cat back in.
Bee hugger. ;)
« Reply #10 on: October 12, 2016, 09:01:00 AM »
Hell, he can come to my house and kill the yellow jackets that have a nest right next to my house.  I'm sure my neighbors won't mind...
« Reply #11 on: October 12, 2016, 09:46:24 AM »
Actually, I'm not sure we have data on the Solo high flow CAT vs. a bypass pipe.  That would be interesting.
2007 BMW Z4M coupe
Recently sold:
« Reply #12 on: October 12, 2016, 12:48:21 PM »
It doesn't have to be specific to our cars. There are many examples on the internet where any CAT, hi-flow or not, is a restriction in the exhaust. Could there possibly be a hi-flow CAT that produces no discernible loss in power? Sure, but I doubt it from all the other examples I've seen thus far.
Offline Jim
« Reply #13 on: October 12, 2016, 07:11:08 PM »
I have the Solo HF Cat and the Solo catless pipe and the catless pipe adds 3psi of boost with no change to the tune and reduces 60 to 100 times by .4 seconds so it's a significant difference.
« Reply #14 on: October 12, 2016, 09:28:51 PM »
We have seen GMPP tuned kappa's get 20-30HP more with a hi flow car and no other changes
It definitely helps.  Turbos are dependent on the exhaust gases.
Offline hammy221
« Reply #15 on: October 13, 2016, 12:09:48 AM »
If a high flow cat would quite it down enough I'd go that route but with how loud it is I I doubt it will help much.
« Reply #16 on: October 13, 2016, 08:32:58 PM »
Ham,  my stage III has a tuned header, hiflow cat, a resonator and two mufflers to quiet it down.
Offline hammy221
« Reply #17 on: October 13, 2016, 10:35:27 PM »
Well S*** lol my whole under will be muffler. Was your so loud it was down right deafening
« Reply #18 on: October 14, 2016, 07:56:19 AM »
I have the SQR2 center outlet.  It has tip mufflers at the end of the pipe.  I also have a mid-pipe resonator.  That took care of the drone cruising, but you can hear it, especially when you step into it.  Of course the whine covers some of that sound.     :lol:
« Reply #19 on: October 14, 2016, 07:52:14 PM »
Fast and quiet is the way to go.
Sneaky.
