Author Topic: C7/ Sky tail light concept  (Read 5576 times)
« on: November 01, 2016, 11:14:41 AM »
Norm, I've been thinking of using the Corvette C7 tail lights for the Sky. Is there a way to fiberglass an adapter/ mount to make these work for our cars? Or I could send it off to metal fab out of aluminum instead. The wiring should be easy enough to figure out.
Offline U4EA
Re: C7/ Sky tail light concept
« Reply #1 on: November 01, 2016, 11:30:59 AM »
I've got an extra set of C7 tail lights if needed, boxed and ready to ship!
« Reply #2 on: November 01, 2016, 11:46:39 AM »
If Norm isn't interested I may buy them from you directly and undertake the project on my own.
Offline U4EA
« Reply #3 on: November 01, 2016, 11:58:58 AM »
Only 9 delivery miles on this set! Been sitting on the shelf for a year now. Removed from a 2016 Z51 3LT.
« Reply #4 on: November 01, 2016, 12:11:32 PM »
Sent you a PM.
« Reply #5 on: November 01, 2016, 01:30:23 PM »
Crude MS Paint job, but you get the picture.
Offline U4EA
« Reply #6 on: January 31, 2017, 09:13:43 PM »
C7 Stingray tail lights
« Reply #7 on: February 01, 2017, 12:28:08 PM »
Are there bulbs in the tail lights or are they LED? I see one connector for each tail light assy. I may end up needing to determine the pinout in order to get them to work. Either way, I still want them and will send payment in the next couple of days.
Offline U4EA
« Reply #8 on: February 01, 2017, 02:31:29 PM »
LED, nothing serviceable in the assembly that I can tell.
Wire harness 2014, 2015 GM# 22781891
Wire harness 2016 GM# 23305614
These tail lights are from a 2016, they all appear to interchange between years without issue.
« Reply #9 on: February 01, 2017, 06:11:23 PM »
Looks like Wire harness 2016 GM# 23305614 is discontinued. I called a vendor and was told the harness was on back order with no ETA. Wire harness 2014, 2015 GM# 22781891 looks to be the only one available.
« Reply #10 on: February 01, 2017, 06:19:31 PM »
Found a good PN for the wiring harness. It's Replacement part number is 23478892.
