Author Topic: Manual transmission replace  (Read 5034 times)
Offline roxer
« on: December 06, 2016, 10:56:43 PM »
Looks like fourth gear is going in the car and I need the transmission replaced. For those who have done it, what's the average time to replace? A local garage gave me nine hours book time. Curious if that's realistic or overkill and I should negotiate that down.
Re: Manual transmission replace
« Reply #1 on: December 06, 2016, 11:50:01 PM »
is that to remove the old and replace with another, or to remove the existing, fix it, then reinstall it?
Offline roxer
« Reply #2 on: December 07, 2016, 12:58:32 AM »
Remove old and replace with new transmission.
Offline hammy221
« Reply #3 on: December 07, 2016, 01:16:38 AM »
I would say pretty close. I've had mine out 3 times and first time it took me 10 hours. But I have a supercharger so about the same as taking the turbo out to remove it.  2nd time it took me 7 and 3rd it took me 5.  But that's after learning all the tricks.
« Reply #4 on: December 07, 2016, 02:54:56 AM »
Sounds about right, if I'm not mistaken, the unbolting starts from rear end with diff (after exhaust of course) and there is some tricky bolts like the one from above of the bell housing.
Offline roxer
« Reply #5 on: December 07, 2016, 12:22:42 PM »
Great, thanks for the info folks!
Do elaborate. Anything I can give these guys to make this go smoothly would be appreciated.
Offline Jimbo10494­
« Reply #6 on: December 09, 2016, 11:38:03 PM »
I need to replace the 5-speed manual trans what alternate trans is available or can the original trans be rebuilt and be beefed up? Using stock motor want to increase HP, only 14000 miles
Vehicle: 2007 Solstic­e GXP with lots of ra­ttles that I am tryin­g to fix
« Reply #7 on: December 10, 2016, 09:15:31 AM »
The stocker is actually pretty stout already.  Unless I'm mistaken, most of Mallet's V8 conversions used the un-modified stock Aisin manual trans.
Offline hammy221
« Reply #8 on: December 11, 2016, 12:57:45 PM »
There's a bolt above the starter. I had to use a series of extensions and swivels and had to go from the front and snake it through the engine compartment above the starter to get that bolt out or you can pull the intake manifold to get to it.  Also for dropping the rear end it was easier to pull both lower ball joints and pull the CV shaft out of both sides rather than just one and wrestling with it. Also if you have a torque arm loosen all the bolts then drop the rear down and pull the rear end with the torque arm attached off the transmission.
Sent from my iPhone using Tapatalk
