Author Topic: Fast Wheels FC04A 19x9.5 +45  (Read 7337 times)
« on: March 21, 2017, 01:39:38 PM »
I posted this in another forum, wanting to get it over here onto kappaperformance.  I went through all this trouble so I can run inexpensive 19x9.5 wheels that are pretty much off-the-shelf.  I made a $1,000 gamble on this, it was almost a disaster but I figured it out in the end.
Diameter: 19"
Width: 9.5"
Offset: +45mm
Tire Size: 275/35R19 Ventus V12
Concentric spacer required, hub is 65.1mm
Long story short, these wheels require a modification.  You be the judge as to how difficult it is depending on your resources and knowledge. Technically, I was able to get the front wheels fit, but mostly likely because the Big Brake rotor is slightly thicker (also, the hub cap wouldn't snap so I machined them anyway).
FCO4A in Titanium:
Final result:
Front Stick Out:
Rear Stick Out:
Trial Fit:
Machine ~5mm off non-structural part of hub see image, this is the part that hits the wheel:
This shows both the shiney machined surface, and the 2nd downside of the CV axle stick out.  I painted the CV axle threads and nut with some flat black paint and blends well:
These wheels on the dyno!
https://www.youtube.com/watch?v=UbbsP0Imyb0
Re: Fast Wheels FC04A 19x9.5 +45
« Reply #1 on: August 25, 2018, 06:54:28 PM »
Just weighed them compared to stock:
Qty 1 Stock 18" with 245 Rapter = 49.8 lbs + small ratchet strap
Qty 1 Fast wheel and tire combo above = 48.3 lbs + small ratchet strap
Consider going to a wider tire with these wheels does not yield a penalty [regarding unsprung weight].
