Author Topic: Twincharged Solstice = Turbocharger + Supercharger  (Read 312555 times)
« Reply #125 on: September 05, 2018, 06:49:24 AM »
Just seeing this last post....I've heard of that happening if you over pressurize the crankcase.... If I haven't read something before go easy on me, but that's what it sounds like to me.  Could you try to vent to atmosphere to see if it keeps doing it?
The two barbs on the catch can input ports, the filter on top is the main vent.  One goes to the factory valve cover barb and the other goes to the barb welded on the valve cover (which goes to the bottom end via factory porting).  Worst case I may need to reinstall the factory baffles I removed [to super clean and then weld the bung on].
« Reply #126 on: September 05, 2018, 07:19:23 PM »
The Air filter on the catch can is the issue.
That and the fact that any Catch Can that is not a paper element design, do not work on our cars.
The Power Performance Catch Can is the only one that has worked for our engines.
Lots of talk about it on Cobalt forums, and they are the guys who built the highly successful Cobalt Race cars.
All of the others just suck and unfortunately your design mimics the bad ones and adds the air filter.
« Reply #127 on: September 06, 2018, 03:15:50 PM »
That is indeed a cheap air filter for a motorcycle.
I would like to learn more about this, thanks for the heads up on checking out Cobalt resources.  Catch cans are very controversial topic these days it seems, in general.
I tried googling power performance catch can, nothing like that came up.  I like to check out that design.
« Last Edit: September 06, 2018, 03:19:32 PM by Steelmesh »
« Reply #128 on: September 06, 2018, 04:22:07 PM »
From the Ecotec Build Book:
And here is my issue and solution it reckon:
*the part about putting the baffles back in.
« Reply #129 on: September 06, 2018, 04:29:42 PM »
What is the basic principle behind your comment on using a paper element?  Are there some key words I can search, I am having trouble understanding this.
The catch can air/oil separator I built is more of a simplified version of this $450 can.  Simplified as in using the a similar principle and physics of swirling air used in many different applications (like dust collection, reduce aeration):
http://www.subispeed.com/2015-subaru-sti/engine/catch-cans/perrin-air-oil-separator-2015-wrx#.W5GLLM5Kipo
Another example of a swirl pot (dry sump system):
Dust collection cyclone:
With your comment about my design sucking like most, I assume you don't mean the catch-can itself, but the system as a whole.
« Reply #130 on: September 06, 2018, 09:00:14 PM »
The purpose of the catch can is to catch.
The designs that are based on just surface area seem to not work on our cars.   Loads of complaints of significant oil in the charge pipes after tunes and or turbo upgrades.
The Powell one has a paper filter element very similar to an oil filter and it simply works.
Check out the attachment.
« Reply #131 on: September 06, 2018, 09:48:09 PM »
Not exactly true. Napi and I installed Provent 200 catch cans that worked quite well. Similar to the one you stated; it also has a paper filter/ element/ cartridge.
http://www.kappaperformance.com/forum/index.php/topic,10327.msg174780.html#msg174780
https://www.idparts.com/mann-provent-200-p-2334.html
« Last Edit: September 06, 2018, 09:52:16 PM by Helios »
« Reply #132 on: September 07, 2018, 08:57:59 AM »
Thanks for sharing.  That is pretty slick, looks OEM.
For my application I think there is some misunderstanding with my setup, I have an off-road racing setup that vents the crankcase completely to atmosphere through the pod filter.  The two hoses on tangent with the catch can air/oil separator come from the engine, one is from the stock valve cover port and the other is from the crankcase port located in the valve cover (there are two ports coming from the bottom end).
I made this sketch of my setup:
« Reply #133 on: September 08, 2018, 08:55:13 AM »
The venting to atmosphere imo is why you are pulling all that oil.
« Reply #134 on: September 13, 2018, 02:18:54 PM »
Return style pre-baffle, the objective of this is to recycle more of the stuff coming out here and hopefully vaporize this crap.  After 150 miles of driving, the main catch can collected about 3/8" of stuff on the bottom, where it would probably be about 6" full.  Looks like it is effective, but will keep an eye on the oil and will get an oil sample out to see what that looks like.  I am still running dino oil, will be switching to full syn.
It's indeed baffled, along with a 'jog' up:
Turned some aluminum to make a nest in the bottom:
« Reply #135 on: September 13, 2018, 07:48:15 PM »
Major improvement once you eliminated the vent to atmosphere but still not the best design.
« Reply #136 on: September 14, 2018, 08:26:27 AM »
It's the same exact setup, just now have a mini baffle in-between the valve cover and the big catch can / air-oil separator.  The mini baffle is installed in such a way to allow crap to flow back into the intake.
« Reply #137 on: September 14, 2018, 11:37:12 AM »
Is there any chance for metal from your aluminum turnings to get returned to the engine?
« Reply #138 on: September 14, 2018, 02:04:14 PM »
Yes, at least they are long continuous curls.  Come to think of it, I have some stainless steel mesh wire cloth, I will rig up a screen in there.
« Reply #139 on: September 14, 2018, 06:09:05 PM »
True,
I think you 2 are the only ones that installed that.  But I do remember that it worked.
As such,  I will remove brand and stick with this statement.
Quote from: elff
and even leave the Critterman english.
« Reply #140 on: September 15, 2018, 02:58:04 PM »
HEY!!!!!!!
« Reply #141 on: September 15, 2018, 05:42:48 PM »
« Reply #142 on: September 18, 2018, 02:51:43 PM »
True,
das mo betta.
« Reply #143 on: September 18, 2018, 08:55:00 PM »
Dyno next Tuesday, Autocross next Sunday, Drag Races the following Wednesday.  The drag race will be huge since I have dubbed this car the "Pony Killer" and there is a printed and updated list on the wall at work for the "Fastest Employee Street Cars".  The top three 1,2,3 are blown Mustangs where #1 dipped into the 12's.  Mind you this is for existing employees and the cars must be driven to the track.
I am up around 17-18 psi and plan to push it; the problem is I cannot hook in 1st and 2nd.  I researched street drag tires or new wheels (Fast FC04A 18x10") and then less expensive street drag tires...not this year gents either way. I already invested in two differentials so this is what I am working with short-term.
Inquiry to drag racers: would you agree that I should go back to stock rear springs just to get more weight transfer while softening up the konis on race day?  For autocross and street I would go back to the stiffer setup...
I digress: and dropped the stock open 3.91 tonight.
*Easy for the 2006 only: Pull the calipers, remove bottom shock nuts, remove rear tie rod, split upper ball joint, pop the half shafts, splay out the knuckles to pull back the half shafts, drop back bone, unbolt driveshaft giubo joint (keep rubber on driveshaft), unbolt front diff mount, jack under the diff, unbolt rear diff bolts, manhandle as shown in picture.
Torque arm diff with 3.73 LSD, 2006 3.91 open, caddy 3.23 open:
And there is a major problem you already know about:
*yes the front diff mount bore is machined on the 2006 while the 2007.5+ uses the torque arm so the bore is rough cast. I enjoy the fact I don't need to deal with a torque arm when swapping and dropping the powertrain and drivetrain (so I am not looking at a torque arm swap).  Also note the torque arm mount bolt boss on top of the front diff mount bore; this interferes with the main front diff mount cast detail.
Few ideas I am contemplating:
1) Machine an aluminum spacer [full depth] that will be pressed in. Grind off bolt boss; I will ensure the mount cannot clock "sneak up on it". Cost is zero and pretty straight forward to perform.
(In my opinion this will work because the spacer will be full length and press fit, so it will transfer the load without deflection as opposed to a loose fit here.  After all this fun, I'll be dealing with the Quaife / 3.23 gears to go with the Twincharger car, so consider any faults here temporary.)
2) Swap the 3.73 LSD gears into the 2006 3.91 diff housing.  Pay someone to do something I might be able to do is a tough one if you haven't figured out by now in addition to saving time if I win.  The risk here is I fail, then that is a potential risk of 6 hours of driving to the nearest 3.91 open diff, rescheduling the dyno pulls, $500.
3) Do nothing; lose to 4 Mustangs after talking the most crap. For example: a new younger tech has a nice 90 Mustang camm'd, and the first day he drove it, I also drove the "Pony Killer" to work and parked next to him. I had no idea it was his at this time; so I went around asking several guys who's black Mustang that was and said it was leaking from the headlights and clear yellow fluid was coming out of it's rearend when I parked next to it.  He is now going to the races and wants a piece of me; and I have done my share of friendly conversation about their little pony's so I am really going to be disappointed if I don't try.
 :devil: #1 :devil:
« Last Edit: September 18, 2018, 09:00:34 PM by Steelmesh »
« Reply #144 on: September 19, 2018, 09:52:21 AM »
The differentials that use the torque arm have 4 bolt locations on the side of the differential that the torque arm mounts to, there is a cast piece from GM that bolts to those 4 locations with a mount in the front that bolts to the same location on the chassis as the stock 2.4L differentials from the 2006-2007 models. That is what is used on all the automatic cars since the automatics do not have a torque arm.
Hope that helps,
Dave
« Reply #145 on: September 20, 2018, 06:56:38 PM »
Turned this last night, the mini lathe does not like the part long so made it about 2x stock length (engagement into the bore):
Win / Fail tomorrow, too exhausted tonight.  Also showing the torque arm mount Dave was referring to.
« Reply #146 on: September 22, 2018, 02:27:15 PM »
It works, the 3.73 swap using the custom bushing.  Judging by some ripping last night, it feels like an improvement in traction.  Few more days until the dyno, I need to start power tuning WOT. I pushed it to 20-21 psi last night.  I am not able to log boost, so today I installed a 5v 0-30 psi pressure transducer for boost (2-bar map on the car), which goes into HP tuners.
I am trying to solve another problem, that convertible top flying open somehow issue; this is most unacceptable to the point of not wanting to drive the car. After investigating the system, the only way it can open is if the handle is opened.  Even if the body was shifting, there are the two pins on the ends of the vert top frame that go into bores on the windshield header, so it can't just shift over and unhook itself.  Instead of zip ties or duct tape, I have installed a 3/8" cotterless pin with a ball detent:
« Reply #147 on: September 22, 2018, 05:59:26 PM »
First time I have ever heard of that happening.
« Reply #148 on: September 22, 2018, 08:20:32 PM »
I've had the top come open a while back because I was a dumbass and forgot to latch it.  After that I learned to be mindful of the top being locked, visuals and grabbing it.  The bad memory comes to me while driving, and I immediately check it. I am okay with saying I could have done it again; since I am for myself I blame it on potholes under full g-force acceleration. If it happens again, whatever happens I am removing all excuses.
« Reply #149 on: September 23, 2018, 08:59:32 PM »
Did some wiring today, bringing new meaning to Flash To Pass.  See if you can figure out what just happened  :thumbs:
https://www.youtube.com/watch?v=xnulUJVButs
