Author Topic: Twincharged Solstice = Turbocharger + Supercharger  (Read 281164 times)
0 Members and 21 Guests are viewing this topic.
« Reply #625 on: November 14, 2025, 07:03:21 PM »
Where am I, it's all a blur, might repeat myself.  More entropy nipping me and my fleet of cars if it's not this it's that, getting rockauto'd with my questionable brand selections.  My HP tuners MPVI Pro took a dump, won't communicate with the PC.  All of my licenses are gone forever HPT cannot do anything but tell me to buy the new one and do the hands thing  :idk:, planning to see if the dang AI can help me figure out what to replace like the USB controller.  I didn't upgrade because they were all marketing Bluetooth as the main new feature of the MPVI 2, my (mis)understanding was they were flashing over Bluetooth which is extremely stupid and irresponsible, so I said No Way Jose I'm not stupid.  Turns out I kinda was stupid since they use a USB cable for flashing with all the new BT capable MPVI's is my understanding now.  I'm kinda butt hurt by HPT, and there are no comparable alternatives out there, EFI live is limited to GM basically, and they don't even support LNF tuning.  Started looking at the KESS3 and Titanium, so expensive but so cool. https://www.alientech-tools.com/kess3/
Leaky turbo cleaned up and reassembled and reinstalled. Replaced the VVT solenoid on the intake side, intermittently stops working, suspect it was messing with me at the autocross races.  -1 point for standalone ECUs, lack of DTCs.  Got an electric smog pump sucking from the crankcase now.  I got the car running again, dialed in the VVT PIDs in no time, where I kept messing with it thinking the ECU was struggling to PID; however was that bad solenoid.
It was not smoking out the exhaust or dripping like before.  That 40psi turbo pressure reg was dropped during manufacture, dented the flare so it was leaking oil,  I am confident it was during manufacture because the damage was hard anodized!
Also added 3 pressure transducers (0-5v): engine out/turbo in backpressure, crankcase pressure, coolant pressure and bring that in through my Analog-to-CANbus box.
« Reply #626 on: January 01, 2026, 02:14:30 PM »
Really looking great Steelmesh despite the issues. Running out of popcorn...   :pop:
 :thumbs:
I hadn't thought of anyone cutting a rib off a belt but for a custom build I can see where it'd be common. Interesting ways to do it.
https://www.youtube.com/watch?v=t3A-gpSGDQg
« Last Edit: January 01, 2026, 02:26:56 PM by Sly Bob »
« Reply #627 on: February 19, 2026, 07:52:30 PM »
 :thumbs:
Thanks Bob, that is a cleaner method I reckon.  Maybe this tool would be advantageous: https://www.amazon.com/NICAPA-Ergonomic-Crafting-Quilting-Replacement/dp/B07VYXZ758
« Reply #628 on: February 19, 2026, 09:49:24 PM »
Spring 2026, the plan is to do whatever needs to be done to autocross the Solstice to dial in the Twincharger system.  I learned a lot taking it to autocross last season, learned it needs some more work.
In other news: Wanted a backup commuter car. Found a sound deal to me on a 2015 Cadillac ATS Coupe 2.0 Performance trim with 100k miles. Rear wheel drive with an auto fit my budget.  Love these GM turbos, should take to a tune well, have a water methanol injection system to install before that step.
« Reply #629 on: February 20, 2026, 12:42:11 PM »
Those Cady's are a sweet ride
« Reply #630 on: February 21, 2026, 12:53:12 PM »
I have yet to put it to the test since I got it (parked through most of winter here), like testing the transmission and checking the rear differential for stress factors. https://www.youtube.com/watch?v=nXdZpYyqjPw
It is because my arm has been in a sling, that day driving out to the ski hill I broke out the ATS just in time to break my body later that day while snowboarding on a boardercross race course they setup, I'm an idiot. :banghead:
« Reply #631 on: August 16, 2026, 04:01:52 PM »
Progress report, since there is real progress and a milestone achieved, it's time for an update. [Insert essay of excuses why this is taking sooo long].
I do want to point out Driver's education in the Cruze and ATS:
6 autocross events
1 track spring Waterford Hills road course
1 track day Mid-Ohio road course
Otherwise, please find out why by what happened over the past 6 months with this side project Solstice twincharger build below:
Overall when I'm wrenching on the car, I'm going back through what I've done years ago and cleaning it up, and then labeling everything more or again with proper nylon cloth label tape out of a Brady M210 which is a great label maker, because it uses that nylon cloth tape (haha) which is made for wiring. From as thin as a hair to as big as you want, the genuine tape is worth it. My prototype wiring is, what it is, spaghetti, that can make things less efficient and daunting as you will find out how much custom electronics is going on.
Tuning: made major progress on tuning cold start and idle, return to idle which I was struggling with last year. Then working on transitioning the bypass valve has also seen success in boost control.  With my system there are 2 boost controllers, wastegate (via gofastbits) + bypass (emu black ecu), right now they're are playing nice with each other.
Turbo: I have been battling a leak around the center section of the AGP 5757 turbo.  Tech led me to install a oil pressure regulator on the feed line from here https://turbosmart.com/products/opr-turbo-oil-pressure-regulator and in addition I also added an electric air injection pump to use as a vacuum pump.  If the pump isn't on, the turbo starts smoking even at idle with 15-20 psi feeding the turbo. I installed a cheap $50 air injection pump here: https://www.amazon.com/dp/B07SBTDS38 and will be getting a GM ac delco unit as the cheap one is failing.  When it works, it works well, it will suck the oil cap back on at idle.
However, fed up with the leak and complications of the vacuum pump (what happens if I lose it), I purchased a 0.82 A/R v-band turbine for the original Precision 5558 that made the 444 whp, which was rebuilt by Precision shortly before getting the AGP.  I never had these leaking problems with that turbo, with a bigger A/R it will work and probably what I should have done in the first place.
Alternator: had stopped charging.  An inherent challenge is controlling the alternator output with the factory ecu disabled.  It wants to see a 5V 128 hz pwm signal.  In addition, there is quite a bit of electrical load on the alternator. Engine fan, heat exchanger fan, vacuum pump, second fuel pump all adds up.  I looked into the high output alternators, they are quite expensive however $400-600.  It may need a cooling duct for air flow since it's tucked in there, however other plans may solve the front space constraints in the form of a rear mounted radiator.
Starter: finally died, it was talking to me prior to this with clicks and slow cranking.  Installed a new ac delco 3371026 starter.  Much improvement there.  I did some voltage drop testing on rear mount battery connections and did see improvement after cleaning up connections and also added another ground to the engine for good measure, that's now 3 engine grounds (factory cable + steel braid + custom 4 ga cable).
In addition, the 14 month old car battery died, this time instead of replacing it with the absolute cheapest one I can find (I have issues, yes), I got an optima for it and am impressed by it's performance and ability to hold a charge compared to the junk I've been running in it all this time.
Analog signals-to-CAN bus output module: fried the onboard 5V regulator so was sending through a higher voltage to the microcontroller.  That is my rookie mistake not feeding it 5V directly (I was feeding VIN regulated 10V).  That may have fried something in the bypass throttle h-bridge controller because that stopped working after working around the blown CAN bus output module, that I can power it through USB for now.
Bypass throttle controller: the h-bridge blew, found that out after a deep diagnosis.  These electrical faults with the custom hardware is tedious and time consuming. I replaced the h-bridge (why I got the 2 pack, yowser!) and got it working again.
Head gasket:  I've been seeping a small amount of coolant somewhere unseen via coolant level creep, and oil seeping around the head and putting it off for the time since I'm running a coolant pressure transducer and don't see a head gasket leak in that data.  I've reused the SCE copper head gasket 2-3 more times than recommended.  After a wonderful day tuning, I bore scoped the cylinders and saw a coolant drip in one of the them (my camera can sweep around and look up at the valves.  Picked up a new SCE copper months ago, and what I got was not for a stock ecotec, looks like it was cut for an upgraded block with 2mm larger hardware.  The original gasket is a line on line fit.  Under a time crunch to make it to the Woodward Dream Cruise, I went with a felpro MLS locally sourced.  I'll be returning the SCE copper.  After buttoning up the head gasket and burping this baby, I lost alternator control, it was not charging sitting at 11.8V.
Alternator control module:  This is another custom microcontroller module to output a 128 Hz PWM signal, the forth arduino microcontroller on this car.  That died, the cpu gets hot and it doesn't communicate.  Swapped that out since I have a bunch of nanos in stock and added protection between the alternator PWM input and the microcontroller (in-line 220 ohm, 10k pull down, 5.1V zener).
CAN bus input module: this reads a stream from the ECU, throttle position, map, rpm, and also outputs the bypass throttle position to the other CAN bus output module so I can log it.  This also lost it's onboard 5V regulator.  I then retrofitted the bypass controller, alternator controller, and can bus input module to run off direct 5V power which solved this challenge.
Milestone reached:
  Yesterday, while road tuning the car and WOT, I hit 93% duty cycle with my injectors at 6900 rpm (current redline 6950).  After a 1-2 gear pull, I said in my brain as it presses against the back headrest, "she's back".  Maxing out my injectors with the proper AFR means the car is putting out the power like the good ol' days on the top end. It was too late last night to make out to Woodward this year, and it's rainy today.  I still got it done enough I think.
Moving forward...
Autocross: yes.
Big wang:  got an alert from Wing-Logic.com several months ago that their stuff is back in stock so I immediately got a WingLogic 74" MSHD Racing Wing Kit Rear Car Spoiler https://wing-logic.com/product/winglogic-74-mshd-racing-wing-kit-rear-spoiler/
The smashed rear fascia will need to come off anyway, will be looking at 3D scanning it and designing a bumper mounted swan neck (I'll custom design it, then send cut send it), that will also allow the trunk to open as normal, so thinking there needs to be a way for it to tilt back.
Injectors: it's time for the ID1050 injector upgrade like I said before if I max out the injectors again I'll get them. I would like to try and run something like E50 because it's harder and more expensive for me to acquire 260 GT 100 octane unleaded, however am running it to dial in the tune before playing with the flex fueling.
2nd ECU to replace the 4 arduino microcontrollers: after much research I landed on a rufis uaEFI, a less expensive engine controller that can run custom code that should be able to control the bypass throttle, CAN bus I/O, analog inputs, control the alternator, and more if I need it.  Being an ECU for engines, it is better suited to handle the electrical environment than a $3.50 arduino nano. The microcontrollers proved the concept out, helped me see what I needed, so now I can move towards optimizing it.
Rear mount radiator: it's going to happen, I just don't know when because....
Roll cage:  I'd like to acquire a proper bender, practice with it and prove I can do it; then build a proper custom cage for this kappa.  Like time attack / hill climb qualified, and for safety over all things.
This is where I can look at the rear radiator mod and go back to an air-to-air intercooler for the turbo. This car is front heavy already with the turbo and supercharger up there.  And rear aero needs to be considered, how do I get enough airflow to the rad without interfering with under car aero like a rear diffuser that you don't want to make inefficient with ducting or heat exchangers.  The one airflow simulation of the Solstice shows that big vortex coming off the rear sides of the car, maybe that's a good spot for some scoops.
« Reply #632 on: August 16, 2026, 05:24:20 PM »
Wow, looks like exciting progress is being made. Quite a bit out of my wheelhouse but glad things are coming along. More popcorn!
  :pop:
« Reply #633 on: August 17, 2026, 11:24:43 AM »
The information
        me
Most of it definately went over myhead but I am glad we are seeing progress agan.....
« Reply #634 on: August 24, 2026, 11:58:07 AM »
Thanks guys!  I'm slacking on the pictures, sometimes that helps  :D
The ID 1050 injectors are installed, was not as easy to calibrate as I thought with the start up, warm up and general fueling being lean or rich. Could be showing deficiencies in the old deka 80 lbs, or possibly it's the lack of injector settings in the ecumaster 2.175 software to properly characterize injectors.  Now at WOT we're down to about 73% duty cycle, where the 80lbs were 93%.
I'm ready to hit an autocross with it and continue dialing in the calibration.  There is an upcoming autocross "Back to the Bank" at the Michigan International Speedway with the Detroit Region.  I haven't been there ever for an autocross so have been planning to go, however last Friday night I looked up to register, and found out 9 people on the waiting list ahead of me.  Hoping they let us in!
« Reply #635 on: Today at 09:10:36 AM »
9 years later...finally have something to show for, and it was glorious  :D :D :D :D :D :D :D
Twincharged Solstice on the track:
IN CAR VIDEO HERE https://www.youtube.com/watch?v=BeCftSQz2Q4[/b]
I am so satisfied with it's performance and finally getting to drive the kappa.  Last year it was dealing with the calibration and controls, I wasn't thinking about learning to drive this platform. That run was a re-run and has revealed a heak soak issue, at the end of that run I was at 100C coolant and almost 100C IAT, 100C = 212F.  It looks like I ran out of water injection fluid some time in run 4 where I got a re-run and hot lapped it back to the start.
To make lemonade from this, I got to validate the IAT correction tables for fueling and knock, fueling needed some adjustment as it was starting to go lean, however the IAT spark table likely took the brunt of it keeping knock at bay.   Also running E50 after running out of 260 GT, wiring up the flex fuel sensor, and tuning it, that was Saturday the day before this race!!
I popped the hood and the primary radiator fan was running.  I was looking into Griffin radiators last night, not sure what to do I'm tossing around that rear mount radiator however after this and my time on the track, I'm thinking the most efficient cooling till be a front radiator.  Might take a look at shifting the radiator back as far as possible, go back to an A2A intercooler, and a lot of hood vent area.   Unless I find a root cause, I am logging coolant pressure and everything looks normal there.  Not sure if I need some type of swirl pot if there is some air bubble issues idk just learned about that gadget (ktuned?).
Correction, I'm satisfied with it running good enough and not blowing up.  It's not done, need to harden it still and other things like a turbo boost dump valve for safety (over boost protection if the bypass TB fails and I'm bordering on boost creep so that is a way to not have to redo my exhaust manifold and install a larger wastegate).
