Author Topic: Leaking Trunk  (Read 1097 times)
Offline rick baum
  • Work at Nuclear Regulatory Commission
Leaking Trunk
« on: August 02, 2017, 11:31:45 AM »
Anyone else having problems with leaking trunk ? I checked the rubber seal on both sides and rear and they are in good shape. Is there a possibility the rain is running down my back window and the nylon basins under the trunk hood are not catching the rain and therefore running into my trunk ???   :(
Re: Leaking Trunk
« Reply #1 on: August 02, 2017, 01:15:30 PM »
Check the rubber boot where the top buttresses attach to the trunk lid.  Also check that the drain tubes in the trunk under the basins are still routed through the holes on the bottom of the trunk.
Offline rick baum
Re: Leaking Trunk
« Reply #2 on: August 02, 2017, 01:17:07 PM »
Great - I'll' check it out - thanks
