Hello all - I'm new to the Kappa crowd with the purchase of my NA 2007 Z0K Solstice in BR Green. It has around 60K on it and someone has swapped out the stock Bilstein's with Koni's. It seems quite a bit low in the front, so could also have had a spring change.
I recently tracked it at the new Dominion Speedway near Fredericksburg, VA twice and found the handling not up to par. Not enough oversteer to make it neutral enough for my taste at speed.Front Koni's are at soft, rears are full hard.
I believe my "Starting Point" will be to determine what springs it has on it currently. I'm likely going to lower the rate in the front, reduce the front bar size or increase the rear spring rate to get my Koni's back to somewhat closer to a middle setting all around.
BTW, my "stage name" HSCoach, is due to my propensity to help unsuspecting students get the most from their track-day experiences. I work mostly with the SCCA in Washington D.C., at Summit Point, South Jersey, Pocono, Watkins Glen, and soon VIR.This coaching has been a habit for the past nine years. I have 17 autos and one truck. Looking forward to learning from this bunch! Thanks!!
