Author Topic: High power-holding clutch option  (Read 3006 times)
Offline nigelt
« on: August 05, 2018, 01:54:08 AM »
I need a clutch for a 2.4 to hold 350ft-lbs+, and it seems the only off-the-shelf options are Spec (with reportedly funky harmonics) and DDM ($$$). Has anyone tried mixing and matching components across the GM line to get a decent setup that's more affordable? For example, the 2.0 stock clutch seems quite decent but would need a 6-bolt flywheel. Or what about out of the Corvette parts bin?
Re: High power-holding clutch option
« Reply #1 on: August 05, 2018, 06:38:49 PM »
If you can get an LS clutch to work, you can easily get up to 1200 ft/lb rated clutches.
But that being said, my gut feeling is it isn't doable. If it was, someone would have done it already.
Don't some 5th gen V6 Camaros use the same trans as the Kappas? Might be a way to make that work more easily than an LS clutch.
