Author Topic: 07 Sky Throwing Nasty Codes... Need Help  (Read 17409 times)
Offline ChrisF12000
Re: 07 Sky Throwing Nasty Codes... Need Help
« Reply #25 on: September 10, 2018, 01:24:45 PM »
Sorry to hear that Chris,  the VVT works on oil pressure and in one of your posts you mentioned sludge during a oil drain and change.  You might need to flush your engine.
What all are they replacing?
Did change the oil but was told that a flush on this engine could be dangerous so I decided not to. The previously mentioned issues are gone but now it's the timing chain.
« Reply #26 on: September 10, 2018, 02:23:27 PM »
Just curious what is the mileage?
Offline ChrisF12000
« Reply #27 on: September 10, 2018, 02:39:37 PM »
118xxx
« Last Edit: September 10, 2018, 02:48:45 PM by ChrisF12000 »
Offline ChrisF12000
« Reply #28 on: September 12, 2018, 08:00:38 PM »
Got it back from the dealer! Everything is fixed... Sort of. Now there's another problem. It's leaking what seems to be transmission fluid!!!
Edit: noticed the power steering fluid is also red and oily. It makes for sense for that to be it since they had to remove it while working on it.
« Last Edit: September 12, 2018, 08:11:00 PM by ChrisF12000 »
« Reply #29 on: September 13, 2018, 04:20:53 PM »
Did they say what all they did to it?  Is it leaking or did they  spill and not do a good clean up?
Offline ChrisF12000
« Reply #30 on: September 14, 2018, 11:21:29 AM »
Went back to the dealer, and they said it was residual. Quite hard to believe since it dumped a lot of fluid into my driveway, but it has stopped. My freakouts are ending because the car is running great now and no problems right now. Thank you all.
« Reply #31 on: September 14, 2018, 03:44:41 PM »
Great, now that the demons are gone, enjoy the ride.
