I couldn't find this code in the 2006 Solstice alldatadiy information, but found it under my Cruze 1.4T haha. Just putting this here you probably already looked at it:
P2271
The ECM detects that the heated oxygen sensor (HO2S) 2 sensor cannot achieve voltage equal to or less than 100 mV. and
The ECM detects that the accumulated mass air flow monitored during the stuck rich voltage test is more than 25 g.
Have you already or do you have the ability to monitor both of HO2S voltage and MAF or cylinder/g? This could be a good excuse to get HPT
edit: I just looked up in my E67 LE5 ECU for "accumulated" mass air flow and can't find this PID to monitor, so not sure what 25 g means, looking furthur I see around idle the cylinder airmass is 0.08 g/sec, * 4 cylinders = 0.32 g/sec, then 25 g divided by 0.32 g/sec = 78 seconds, so looks like its just integrating the mass like I just calculated, 78 seconds seems reasonable from my understanding.
Conditions for Running the DTC:
DTCs P0068, P0096, P0097, P0098, P00B6, P0101, P0102, P0103, P0106, P0107, P0108, P0111, P0112, P0113, P0114, P0116, P0117, P0118, P0119, P0121, P0122, P0123, P0171, P0172, P0201, P0202, P0203, P0204, P0222, P0223, P0300, P1101, P1516, P2096, P2097, P2101, P2119, P2135, P2176 are not set.
The ignition signal parameter is between 10-32 V.
The fuel level is greater than 10%.
The engine speed parameter is between 1 100-3 500 RPM.
The mass air flow (MAF) sensor parameter is between 1-30 g/s.
The fuel composition is less than 87% ethanol.
The fuel system is in Closed Loop.
DTC P013A, P013B, P013E, P013F and P2270 have run.
DTC P013A, P013E and P2270 have passed.
DTC P2270 runs once per drive cycle when the above conditions are met for 5 s.
Not sure why it is mentioning P2270 in the above, this is conditions for setting P2271 so idk
