Author Topic: 2.4 Muffler Delete  (Read 5659 times)
Offline CarolinaSolstice
2.4 Muffler Delete
« on: December 07, 2019, 03:59:18 PM »
Anyone ever cut off the muffler and run straight pipe with just the resonator?
Did u like the sound?
Look up and read Charles Swindol "Attitude"
PONTIAC FOREVER!!!!!!
Re: 2.4 Muffler Delete
« Reply #1 on: December 08, 2019, 10:42:12 AM »
My personal opinion is the problem with open exhaust on a stock car is you can't get through the gears fast enough because you don't have enough power, so your car ends up being a really loud slow car.  You'd get street cred until the moment you with WOT, at which point you go full ricer.
I know how it is when you want to upgrade your car or modify it but don't have all the knowledge and money to do it, so I agree a muffler delete is a very cheap easy mod and if this gets you involved with your car and modifying it I encourage you to do it (literally doing the mods with your own hands). I'm not too familiar with the stock exhaust, I am thinking if there is a slip joint you can try to remove the muffler temporarily just to get a better idea if that is something you want to do, this way you can go back to stock in-case you don't like it.
Ecotec cars with racecar exhausts without racecar engines:
https://www.youtube.com/watch?v=PlkvXY6bOjU
Unknown Ecotec exhaust, but likely NA:
https://www.youtube.com/watch?v=FebP-UhLQQ4
Launches WOT at 3:23:
https://youtu.be/zpP6XsVM1Cw?t=139
Ecotec car with racecar exhaust and racecar engine:
Turbocharger dump pipe:
https://www.youtube.com/watch?v=cc2I1gxD2Zc
Turbocharger, catlytic converter, muffler...revs pretty quick since it has an aluminum flywheel:
https://www.youtube.com/watch?v=NvtuDaAoJ2I
« Reply #2 on: December 13, 2019, 03:42:25 PM »
After some more thought I'm afraid I'll lose some low end torque if I remove the muffler and with this little N/A 4 banger I don't want that.
« Reply #3 on: December 14, 2019, 09:55:25 AM »
Free flowing is free flowing...I'd worry more about that on the intake side, and just get a nice glasspack setup for the exhaust if you want loud. (Which, kinda ironically, would flow better than a straight pipe setup...)
« Reply #4 on: December 14, 2019, 11:01:44 AM »
I had a guy a few years ago that owned a muffler shop tell me that freeing up the exhaust on a 4 banger will make it slower off the line because you don't have the back pressure anymore....that's why I said that.
So you're saying if I add a CAI I can make it slower off the line?? Hope not, I have one on order!
Any suggestions on what glass pack set up to get?
« Reply #5 on: December 14, 2019, 02:30:13 PM »
https://forums.mightycarmods.com/forum/technical/tech-talk/3416-backpressure-the-myth-and-why-it-s-wrong
There's plenty of other sources out there debunking this common myth, but here's a good explanation.
I was more referring to intake manifolds, some do rob you of torque. CAI isn't likely to add much, if any, power, but it's not likely to steal any either.
Offline marksbug
« Reply #6 on: January 17, 2020, 11:24:03 PM »
 just put a good muflfer on it that you like the sound of. or if you do want more power and a little louder is waht your after than put a turbo inplace of the muffler and run tubing up front....or just put the right turbo kit on. I doubt you will get much more if any out of the oe muf being cut off. The car needs a real header .( I have  a "name brand" solstice header...it's pure shit and expensive) then a better muffler may help.  if you deleate the muffler it will sound like hammered dog shit splattering on the walls.it is not a race engine.
