Author Topic: Hello  (Read 6885 times)
Offline Sandshark
Hello
« on: April 27, 2021, 09:02:45 AM »
New guy - recently picked up a 2008 Redline in NJ.  Lots of fun when the CEL isn't on, haha.  Fighting with it over a P0101 code, working through troubleshooting, I am sure I will be asking questions.
Re: Hello
« Reply #1 on: April 27, 2021, 09:34:19 AM »
Welcome to the forum.  MAF codes can be a pain, pickup some cleaner and give it a shot.  Do you have the GMPP upgrade?
Offline Sandshark
Re: Hello
« Reply #2 on: April 27, 2021, 09:43:33 AM »
Nope no tune, guy before me just has the RPM dual cone CAI, no other mods as far as I can tell. MAF looked pretty new, I cleaned it up anyway but same result.  Adjusted the wastegate, same deal.  I keep monkeying around with the throttle body elbow, I think I am going to replace it and put on upgraded clamps, has the originals on there, wonder if they are the leak.
Car seems to be holding boost fine, it happily gives me 15-16 psi and seems solid through the power-band.  Just after 40 or so miles the ECU throws the code and cuts down the turbo.  So it makes me think it is more sensor related than a physical leak, not sure it would hold 16 psi fine and be leaky.
Re: Hello
« Reply #3 on: April 28, 2021, 04:32:42 PM »
Welcome to the forum, hope you get your issue resolved soon.  Try cleaning the connectors as well.
Re: Hello
« Reply #4 on: April 28, 2021, 05:15:57 PM »
Re: Hello
« Reply #5 on: April 29, 2021, 12:29:46 AM »
#1 cause of P0101 code- boost leak.
Remove all factory clamps and replace with upgrades. While you are swapping- wipe all tubes.
#1a- look for broken nipple at pipe end of rubber hose for crankcase vent.
#2 cause- ballooned factory original IC. Hard to see until you see it. Look for a hippo hiding in your IC
#3- bad GMPP upgraded sensors- need to hard solder wires and remove crimp connector. (Not likely your issue if you are all original)
#4- bad tune. Retune to solve. (Again- not likely you)
Re: Hello
« Reply #6 on: April 29, 2021, 05:58:59 AM »
If the RPM air filters were coated with oil, that could be your problem also.
Offline Sandshark
Re: Hello
« Reply #7 on: April 29, 2021, 11:55:27 AM »
Thanks for the welcome guys.
Would cone type filters be oiled?
Also not a stock hood, its a fiberglass deal with the vented scoop in the front - thoughts on water ingestion as throwing off maf in intake?
I am getting a new OBD scanner to run with the car so I can see what the MAF is doing while I drive.  Yesterday was significantly warmer than any previous day i've had the car - car started in limp mode in the morning and came out of it after 10 minutes of driving and dropped the CEL... then drove happy as a clam for the rest of the day. I am wondering if the warmer air dried it out a bit maybe?
Offline Sandshark
Re: Hello
« Reply #8 on: April 29, 2021, 12:04:12 PM »
I'll throw up a pic too since what's the point of getting a new car without showing it off a little.
Re: Hello
« Reply #9 on: April 29, 2021, 12:48:45 PM »
Like Gentleman Jack mentioned there is a good possibility that your intercooler is swollen and leaking. You really should take the time to test with a few fittings and a compressor to see if you have leaks in the charge system. Here is one way a member years ago tested his.
http://www.kappaperformance.com/forum/index.php?topic=5000.0
This is the device I sup together to test. I just hook it up the same as Kenny did and hooked it to my compressor. Keep the pressure low and below 20 PSI or so or you WILL have leaks.   :barf2:
« Last Edit: April 29, 2021, 12:57:04 PM by Sly Bob »
Offline Sandshark
Re: Hello
« Reply #10 on: April 29, 2021, 01:55:40 PM »
Ah thanks, seems much easier than taking the front off to visually inspect the IC.
Re: Hello
« Reply #11 on: April 29, 2021, 02:08:58 PM »
Yeah and you check for any other leaks in the system at the same time. You might find this thread by Gentleman Jack informative as well.
http://www.kappaperformance.com/forum/index.php/topic,6161.msg86769.html#msg86769
« Last Edit: April 29, 2021, 02:12:50 PM by Sly Bob »
Re: Hello
« Reply #12 on: April 30, 2021, 05:10:11 AM »
That's a Norms Fiberglass Hood.  Very nice
Re: Hello
« Reply #13 on: April 30, 2021, 10:30:45 AM »
ACTUALLY, it's an RKSport hood...    ;)
Re: Hello
« Reply #14 on: May 01, 2021, 06:35:58 PM »
Thanks Bob
Re: Hello
« Reply #15 on: May 02, 2021, 01:02:55 AM »
I didn?t think Gentleman Jack ever did anything worthwhile on this forum?!?!
Re: Hello
« Reply #16 on: May 02, 2021, 12:38:34 PM »
He lost a bet with me once and I ended up with a few cans of Guinness, I would call that worthwhile.
Re: Hello
« Reply #17 on: May 02, 2021, 01:34:58 PM »
He must have been having an off day and an amount of alcohol may have been involved I suspect.     :D
Re: Hello
« Reply #18 on: May 02, 2021, 05:38:42 PM »
Ah he is okay when he doesn't have any bubblegum pink paint.
