Author Topic: Wester's GMPP Tuning begins  (Read 105992 times)
Re: Wester's GMPP Tuning begins
« Reply #125 on: June 15, 2009, 08:57:14 AM »
With the proper tires and a good track a WG car that is pumping 289RWHP and 340 Torque will definitely be on the 12's.
Just for the record that is incorrect LV you can figure HP from the 1/4 times, not the other way, and it is a very complicated formula. There are these things called differentials and gearboxes that also effect 1/4 mile times, not to mention dyno numbers are just a reference and then there is wind resistance as well, and the weight of the car yada yada yada. DBG has the a fore mentioned HP and Tq and ran a 13.5 with very good reaction times. You can not bench race with dyno numbers it doesn't work.
« Reply #126 on: June 15, 2009, 05:50:06 PM »
Someone on the sky forums posted running a 8.3 1/8 mile with the GMPP + Westers. If you use this chart to see what that would equal in a 1/4 mile then it would be a 12.95 which seems to be faster than what anyone can post with just the Westers regular tune. But I do agree if someone is able to do 3 dyno pulls on same day same dyno with one being GMPP, Second being Westers, and third being GMPP+Westers then that would be awesome.
Link to 1/8 mile to 1/4mile converter. http://www.eldemoniorojo.com/calculator.htm
I just did over 20 runs on 1/4 track this weekend, my best time was 13.5s with stock + WG (custom backbone and custom throttle elbow), everything else is 100% stock, I just modified my tire pressure.
Reaction time was 0.496 and 1/8 time was 8.679 compared with 8.3 this means somewhere between 12 and 13 for 1/4 by pure approximation
« Reply #127 on: June 15, 2009, 08:13:23 PM »
Lil goat, you are correct but I am not the one posting these RWHP, and torque numbers.
However if the numbers are there, then base on those complicated formulas you mentioned the car should be well into the 12's.
If this is not the case then the numbers are inflated.
Every time I see Lyndon numbers from his garage, they are probably pretty accurate as to what the engine is actually pumping out.
If my memory serves me right, they have always been on the high 240's to low 250's.
I then see postings by members using his work\tune, but on other Dynos, and then the numbers are inflated.
Understand, I have always stated that a Dyno is a tuning tool, and what should be look at, is what number(s) were recorded before the tuner started the session, with the numbers the tuner was able to obtain after the tune.
This is the reason we were all very skeptical of the tunes in Orlando, by the other tuner and what he claimed he could do.
« Reply #128 on: June 16, 2009, 08:00:11 AM »
Not using the Solstice as an example as it is true for all cars, you can have a 400 HP car that will not crack 14, and a 300 hp car that will do 11's. It is all in the setup, there is no way to predict 1/4 mile times from dyno numbers without more expertise than most of us have. 1/4 mile times are not a finite number and neither are dyno numbers. The old Cadillac De Ville had 460 hp stock, can it do 10's ? Then of course there are the driver, track, tire, temp variables. Just can't predict 1/4 mile times from dyno numbers. There are plenty of 1000 hp Civics that can barely make it into the 12's. What would you guess a 1450 hp Cobalt Funny Car would do, it does in the 7's most days.
Lyndon's dyno numbers are from a Super Flow eddy current dyno, one of the most accurate there is. He posts his numbers with NO COMPENSATION, all most all dyno operators use compensation so there numbers are close to Dyno Jet numbers, the adopted standard for comparison only. Dyno Jets read higher numbers, they are inertia dyno's not eddy current. Where I had my car dyno'd he used a 9% compensation I asked. so on Lyndons's dyno my car would dyno about 261 instead of 287. In most of the articles you read about HP vs. 1/4 mile times they are using Dyno Jet numbers, it has been the standard for many many years, it at one time was the only type of dyno you saw commonly.
« Last Edit: June 16, 2009, 08:06:17 AM by lil goat »
« Reply #129 on: June 16, 2009, 08:37:42 AM »
This is one of the reasons I went with Westers in the first place.  He was always true to his word and posted the most accurate and "real" numbers.  Plus, he has invested a lot of his time into making this tune the most efficient it can be, knowing that his updates are free.  This is someone who is trul dedicated to making an automotive owner into an enthusiast.
« Reply #130 on: June 16, 2009, 09:51:47 AM »
I don't care how much power I have, as long as I can keep getting more :)
« Reply #131 on: June 18, 2009, 08:13:50 AM »
I have a new No Cat tune from Lyndon based on HP Tuner scans from my car, yet another reason to have HP Tuners. If it ever stops raining I will let you know, but I can say I was accelerating in third gear, not in it hard at all and about 4000 rpm the car started to get sideways, it was raining but it didn't used to do that. Tune is really smooth and has a very nice tone, with just enough burble when you back off. Lyndon is never satisfied, he keeps trying new stuff to make our tunes better.
« Reply #132 on: June 18, 2009, 08:38:00 AM »
nice to hear that goat, can't wait to get my new IC and exhaust.
Any news about the sensors?
I can't afford to buy whole GMPP package just for those 2 sensors and their connectors, I remember Lyndon saying something he is close to acquire those for people like me.
« Reply #133 on: June 18, 2009, 08:51:58 AM »
Kelu...keep your eyes open over the summer for something involving the sensors.  I am not sure I can say much about it, but there will be another option coming.
« Reply #134 on: June 18, 2009, 08:59:28 AM »
I'm here  sir, I keep my eyes wide open, hurry up I will attend two race weekends in the early August and King of Europe in early September in the neibourhood country, I want to go there prepared to battle for 1st position in my group and not gaining 2nd place anymore :)
« Reply #135 on: June 18, 2009, 10:23:28 AM »
Kelu you can buy them in Germany, you might be able to order them even. We just can't buy them in the states they are also used on the Alpha Romeo turbo. Here is the parts list
1 - 11589015 Bolt Tmap Sensor
2 - 88988320 Connector Sen-MAP w/ leads
1 - 12602863 Sticker Premium Fuel
1 - 12626987 Label Cert
2 - 12626998 O-Ring T-MAP
2 - 55206797 Sensor T-MAP (Bosch Part # 0 281 002 845, supposed to be used on Alfa Romeo 159 1.9 JTD)
1 - (npn) GM Performance Decal (missing from my kit)
1 - 19212711 Instruction Sheet
« Reply #136 on: June 18, 2009, 01:42:47 PM »
What about the first 3 parts (bolt, connectors and o-rings), I will not need those?
I think I will be able to find those 2 T-Map sensors around here, I found out they are used also in Fiat Doplo 1.3 JTD build after 2005.
« Reply #137 on: June 18, 2009, 01:52:49 PM »
The sensor pinouts are different from the stock sensor.
The oring is larger than what comes with the sensor that fills the gap as the hole it plugs into is larger.
The bolt is to match the IC insert threads. You may find one locally.
« Reply #138 on: June 18, 2009, 02:26:33 PM »
« Reply #139 on: June 18, 2009, 02:36:26 PM »
Aye Aye Captain, starting to search for those too.
Offline Imaj
« Reply #140 on: June 18, 2009, 02:51:19 PM »
Spiky...I am going to put two and two together...based on your post and say that t...Na never mind. I do not want to be right and deal with the guilt.  :drag:
Offline GregGXP
  • Go NAK3D
« Reply #141 on: June 18, 2009, 03:31:50 PM »
Okay, so I have been searching, reading etc... anything and everything related to GMPP vs. Westers, GMPP plus Westers and I am still confused as to the best course of action.
So my 2008 GXP has the Solo RCD but that's it for performance mods. I currently have a tentative scheduled appointment to have the GMPP kit installed next Friday at Koons (Thanks LG). After reading a few posts however, I am now wondering if I wouldn't just be better off going with Westers and just forgetting about the GMPP tune.
If I go ahead with the GMPP tune I was thinking it would be a good idea to purchase HPTuners before next Friday, download my stock tune, then once the GMPP tune is installed download that so that I have both the stock and GMPP tune stored and then a little down the road look at adding Westers.
My concern is that I am just wasting money on the GMPP kit...
Thoughts?  And thanks in advance for any advice.
Greg
2008 GXP, Mean
Solo RCD: Norms Diffuser: JPM Shifter:
DDM Backbone:
Westers Tune - To Be Installed
NAK3D is like a box of chocolates
« Reply #142 on: June 18, 2009, 03:41:34 PM »
Cancel your appointment for GMPP and wait.
Offline GregGXP
  • Go NAK3D
« Reply #143 on: June 18, 2009, 03:46:32 PM »
Thanks Kenny... I understand your "wait" comment based on a few of the posts, but I really don't want to wait any longer.
2008 GXP, Mean
DDM Backbone:
« Reply #144 on: June 18, 2009, 03:46:53 PM »
The GMPP is a canned tune that works great, but it will not take advantage of any other mods you do.
An Aftermarket tune can be customized for your specific mods, especially a Cat Delete
As such, I think you should skip the GMPP tune.
If you purchase HP Tuners, you can save yourself the hassle of shipping the ECM and also make sure you have a backup of your existing Tune in case you need to take the car to the dealer.
« Reply #145 on: June 18, 2009, 03:48:06 PM »
Also
you don't need to wait.  Get the Westers Tune now
and when it is updated
Get your Free Update
« Reply #146 on: June 18, 2009, 03:50:55 PM »
If you can't keep it in your pants anylonger, then  :agree:
« Reply #147 on: June 18, 2009, 05:14:33 PM »
GregGXP I was in your place some time ago, but because GMPP kit is not available in my country it was easier for me to decide.
Instead of paying GMPP over $600, HPT $500 and another $600 on Wester's Race Tune I can point you some other way to approach this:
Cancel GMPP and go for Wester Race directly. Belive me, in this stage will be more than enough. In some time when you will get used with it probably will be there a cheaper solution than buying both in order to achive highest performances.
You can go for Western Race Tune by different ways through HPT which is most expensive but best in long term, spare ECM mid solution or have someone around your place reading/writing your ECM and paying the credits to his HPT.
Offline Deep-GXP
  • BooYah!
« Reply #148 on: June 18, 2009, 05:44:31 PM »
Greg
For now it sure seems that GMPP + Westers Garage Tune is faster than Westers on Stock Sensors.    But anyway, you can go ahead and Purchase Hp tuners + Westers tune now and get your tune asap.  You can later install the GMPP kit and westers can also send you a tune for the new sensors.   You also said you wanted a copy of your stock tune and stock gmpp tune, but once you get the gmpp kit installed you can forget about the stock tune altogether, there's no going back lol.  Hope this cleared something up :)
By the way,  I bought an extra ecm and then i bought westers tune and shipped my ecm to him.  Then i realized the convinience of Hp tuners so then I bought HP tuners, and now I have purchased and installed the gmpp kit.  This is as expensive as you can get to just get an ecm tune but im satisfied.  I cant wait until Lyndon can do some real testing on the gmpp kit :)
:dancing::dancing::dancing:
Offline Deep-GXP
  • BooYah!
« Reply #149 on: June 18, 2009, 05:45:30 PM »
A brilliant thought just occured to me lol.
Lyndon should also install his water/meth kit onto his car and so some serious testing with GMPP Kit + Water/Meth + Westers tune :)
Im really debating getting a water/meth system but I kinda want more information on performance gains and I want to know that Lyndon for sure has tunes available for it and what to expect :)
If he does this im sure he can make some decent water/meth system sales ;)
