Author Topic: Taking GXP out of 6 month hibernation  (Read 2726 times)
Offline gxpsly1
« on: April 16, 2009, 06:41:19 PM »
I will be taking the GXP out of hibernation in a few days. It has been on the battery tender and not started for almost 6 months. I would like to turn it over a few times without starting to get some oil back into the engine. Good idea or unnecessary? It appears that if I pull fuse 45 in the under-hood fuse block the injectors and ignition coils will be disabled and the car would not start when turned over. Any thoughts appreciated?
Offline Excelsior
Re: Taking GXP out of 6 month hibernation
« Reply #1 on: April 16, 2009, 07:21:18 PM »
Just start it and let it idle for about 20 minutes to burn off any contaminates in the oil.  I have never needed a battery tender and just disconnected the battery from the car and never have had any issues.
It should start on the first crank like it was never at rest.
Offline Excelsior
« Reply #2 on: April 16, 2009, 07:21:40 PM »
Then change your OIL that day.
« Reply #3 on: April 16, 2009, 07:44:54 PM »
I too dug my GXP out and started to use it again not long ago.  It however didn't sit for 6 months unused as I will drive it during the winter if the weather is nice and the roads are salt, ice, and puddle free, I think I drove it once in January.
I'm not sure what you gain by turning the engine over without starting it just to move the oil around.  If there is no oil on the bearing surfaces wear is still going to take place whether your just cranking it or you start it.  If there were no oil on the bearing surfaces I would be more worried about rust forming on them as rust will cause a lot more damage.  That being said I have pulled apart engines that haven't been run for literally years and there is always some oil on the bearings, sometimes there is rust too but your car has only set for 6 months and you should be using a high quality oil.
Also the starter on our cars is computer controlled and I don't know what might happen if you disable the injectors/coil and then try to crank it over.  Assuming that you can safely crank the engine with the ignition and injectors disabled you probably should remove the spark plugs so that the starter motor has an easier time turning the engine over, less wear and tear on the starter and battery.
Personally I think you will be doing more work then its worth to disable things just to crank the engine over for a few seconds.  Something else to consider did you add an oil pressure gauge?  If not how will you know if you have any oil circulating through the engine, I don't think that the idiot light really tells you anything while you are cranking the engine over.
I would, and did when I started using mine again, give the car a good going over check all the fluid levels, look under the car for any signs of a leak, check the tires for proper pressure and test out the lights to make sure that they work then get in and start the engine and go for a drive.  You might want to do a brake check before you get to any real speed and then just enjoy the car.
Offline gxpsly1
« Reply #4 on: April 17, 2009, 08:03:01 AM »
Thanks for the input. Sounds like I was over thinking this. I guess the plan of the day is warm it up, change the oil and filter, make sure everything is in working order and enjoy.
Offline Gunnys GXP
  • SEMPER FI
« Reply #5 on: April 17, 2009, 08:43:09 AM »
Yep.  Nothing fancy to it.  Took a great 5 hour drive yesterday in the 60 plus weather.  70's today baby.  :woohoo:
Offline sol_man
  • Enjoying the cool summer
« Reply #6 on: April 17, 2009, 10:26:24 AM »
 :agree:
I took mine out yesterday with the top down, had the heater on but today that shouldnt be a problem!!  Too bad I have to work.....
0-60 in 4.37 seconds
Offline Gunnys GXP
  • SEMPER FI
« Reply #7 on: April 17, 2009, 12:46:27 PM »
:agree:
Watch yourself, the cops are in the pullover mood.  They got me yesterday at 82 accelerating after being stuck behind a row of passing big rigs.  I gave him the "HMM, I just recently had a new guage face put on, I guess the needle is a bit off" line.  Actualy put it on in 07 but it worked and he let me go.  :lol:.  he said just bring it down a couple under 80 so the ten-o-ver rule is apparently still in effect.  Think they are just gearing out warnings now that summers coming.
