Author Topic: How To: install footwell lighting  (Read 53252 times)
Re: How To: install footwell lighting
« Reply #50 on: July 20, 2023, 09:47:51 AM »
The lights in the mirror do always pass a small amount of current - enough to light LEDs dimly (not enough to light the original bulbs, but the current is still there). The fuse is just a protection device, smaller is better, but it won't make any difference to battery drain.
The issue may well be to do with how the wind deflector is wired.  Power should be from an "accessory" source, only on when the car is on.  You obviously have it powered from a battery source (always on).  As such it can fool the battery drain circuit in the car to not turn off the supplies, and so drain your battery.
Offline johnnyh12
« Reply #51 on: July 20, 2023, 04:38:39 PM »
The wind deflector is wired to the same wires as the footwell lights, but they are not on all the time.  All three go to fuse 27 and the grey wire.
« Reply #52 on: July 20, 2023, 06:18:30 PM »
Change your wind deflector 12V power to an accessory supply.
Offline johnnyh12
« Reply #53 on: July 25, 2023, 05:05:06 PM »
I'm still trying to figure out why only the red LEDs come back on AFTER 10 minutes have passed since closing my doors, and how I might fix that.
« Reply #54 on: July 31, 2023, 05:44:02 AM »
I had to install a solid state relay to control the circuit and cut off power.
