Author Topic: Need some help removing a few parts  (Read 2289 times)
Offline skyguy1984
« on: June 01, 2009, 11:19:39 PM »
Hey all i need some help, i need to know how to remove 3 parts on my saturn sky redline,
the door handles,
the hood vents,
and the chrome plastic shroud beside the fog lights.
thank you all in advance!!!!!
Re: Need some help removing a few parts
« Reply #1 on: June 02, 2009, 12:35:20 AM »
I'm interested in this also
DarkSlySol
« Reply #2 on: June 02, 2009, 03:52:27 AM »
For the door handles I belive you have to remove the door panel and behind the plastic covering inside and unscrew them...not a 100% sure but i so believe that how u do it, but BECAREFUL those door handles are SUPER fragile
« Reply #3 on: June 02, 2009, 05:30:54 AM »
Door handles, outside, remove the interior panel, then with the window raise, use a #10 socket to remove 3 bolts.  Apply some grease to the socket so the bolts don't drop off.  Then the front of the door handle has a clip that needs to be pushed to release the handle.  Pull out the handle (with the handle opened like you are trying to open the door)  slide off the unlock rod..
I'm not sure on the other two pieces.
