Author Topic: The GM tune real numbers  (Read 6866 times)
Offline Mr.Marky
« on: June 06, 2009, 06:39:04 PM »
OK so finally here they are. The before run was done last year with about 12,000 miles. This run with about 20,000 miles. The temp was about the same.
 Before GM tune                           After GM tune
S      RPMX1000    HP             S      RPMX1000  HP       FT-LBS
                                          0.42   3.10      54.04    91.53
                                          0.55   3.20      72.36    118.74
                                          0.69   3.30      81.67    129.97
                                          0.77   3.40      83.85    129.53
0.22   3.50        71.34            0.88   3.50      87.89    131.88
0.34   3.60        85.39            1.00   3.60      92.38    134.77
0.51   3.70        97.57            1.09   3.70      98.50    139.80
0.62   3.80        108.64          1.18   3.80      108.33   149.71
0.72   3.90        121.64          1.32   3.90      121.31   163.36
0.84   4.00        135.11          1.44   4.00      132.62   174.71
1.08   4.10        146.96          1.58   4.10      146.30   187.41
1.49   4.20        153.24          1.80   4.20      158.78   198.56
1.97   4.30        157.77          2.26   4.30      163.02   199.12
2.48   4.40        160.25          2.67   4.40      168.78   201.47
2.82   4.50        165.25          3.14   4.50      169.64   197.99
3.23   4.60        168.45          3.50   4.60      175.38   200.24
3.63   4.70        171.00          3.87   4.70      178.78   199.78
3.96   4.80        178.54          4.16   4.80      187.61   205.28
4.32   4.90        184.66          4.49   4.90      193.97   207.91
4.72   5.00        186.34          4.83   5.00      198.96   208.65
5.04   5.10        193.41          5.10   5.10      208.96   215.19
5.46   5.20        192.66          5.44   5.20      213.51 *215.66*
5.85   5.30        193.54          6.79   5.30      215.42   213.47
6.22   5.40        196.64          6.18   5.40      213.48   207.64
6.62   5.50        196.68          6.56   5.50      212.45   202.87
7.05   5.60        193.60          6.93   5.60      211.81   198.65
7.50   5.70        193.40          7.29   5.70      214.33   197.49
8.39   5.80        197.49          8.17   5.80    *219.28* 198.57
8.79   5.90        197.76          8.60   5.90      212.42   189.10
9.16   6.00      *200.11*        8.97   6.00      208.63   182.63
9.50   6.10        191.34
The car is stock but for a K&N air filter. A 07 Sky with Auto.
Re: The GM tune real numbers
« Reply #1 on: June 07, 2009, 08:51:13 PM »
That's a nice increase
Bet it drives real nice now
 :thumbs:
« Reply #2 on: June 07, 2009, 08:53:58 PM »
What were the TQ#'s before the GM tune looks like they didnt post only the TQ#'s after the tune.
« Reply #3 on: June 08, 2009, 06:48:12 AM »
Having seen dyno runs on an auto before the stall converters really mess with the dyno, you are not seeing a really accurate number (should be higher) but the amount of change should be correct. Nice increase.
Offline Koobie
« Reply #4 on: June 08, 2009, 03:09:59 PM »
215 ft-lbs??  I'd go demand a refund.  325TQ X .85 = 276TQ
Even at a 20% loss its 260TQ
2001 BMW 330Ci
2007 Sky Red Line
Both paid for...woot! :)
« Reply #5 on: June 08, 2009, 03:55:02 PM »
Looks like this Dyno is stingy which is the case with some, especially Mustang Dyno's
The main thing you want to look at is to see if there is an increase in the before and after which he did get.
« Reply #6 on: June 08, 2009, 04:21:38 PM »
Dyno #'s should only be used to assess weather a mod works or does not work and where the power is located and for how long and should not be used for anything else period.  You can have higher #'s than me but I could still be way faster down the Qtr mile.  It's all where the power is located and the longer it's there that makes the difference.   Your really better off going to the track so you can get an idea of where your at speed wise, reaction time wise and time wise.  Just my 2 cents though.
Offline Mr.Marky
« Reply #7 on: June 08, 2009, 08:19:10 PM »
Your both right the car's manly ran at this place are mustang's. And i do believe this dyno shows #'s a little low. But it is about the diff from run to run. And a dyno run has nothing to do with a QTr Mile run. But the % of change is the important thing here. That % should hold ture for all our cars. The place i had the run done at did upgrade there software in the last two months. So now they can test for ft-lbs. and boost, which wouldn't read over one bar for some reason. SO next time if it's working i will post those #'s too.
Offline LiquidPT
  • TechHead
    • LiquidPT's website
« Reply #8 on: June 08, 2009, 08:48:05 PM »
No no. Musstang is a brand of dyno...
LiquidPT aka Matt
driving Black Sun
Offline Mr.Marky
« Reply #9 on: June 08, 2009, 10:38:34 PM »
see happens when u don't sleep...u read things in funny ways. It was a Dynojet, if u wanted to know..
« Reply #10 on: June 09, 2009, 06:44:37 AM »
I saw Chucks car dyno'd with the same tune and setup as a manual it read 40 hp lower because it was an auto, the stall converter in the car just pisses the dyno off, don't look at the numbers look at the change LIKE I SAID BEFORE.
Offline chuckdoc
« Reply #11 on: June 09, 2009, 07:25:41 AM »
Hey we will see what happens when we go to the track.  Joe is putting something together.  1/4 mile time is the main thing I am interested in and comparing my gm/westers  tune to Joes Westers tune.
My KappaPerformance Mod Page
« Reply #12 on: June 09, 2009, 07:57:34 AM »
If anything I expect your car to be faster Chuck, it just doesn't show the correct numbers on the dyno because of the stall converter. Should be an interesting day at the races as they say.
Offline chuckdoc
« Reply #13 on: June 09, 2009, 12:43:22 PM »
Yeah, but remember Joe got a new CAI and a haircut!  He might be really fast!
Offline DickW
« Reply #14 on: June 09, 2009, 04:52:31 PM »
Chuckdoc, What are you doing 0-60. I did a 0-63-4.60 this morning according to my Dashhawk. I have the gmpp tune. I am getting a Wester tune this week. Mine is also an auto.
Offline chuckdoc
« Reply #15 on: June 09, 2009, 07:43:27 PM »
Wow, thats really good times.  On the day Joe and I tried to get a 0 to 60 time, we just kept spinning the tires.  Now with the probeam, I do not seem to spin them so much so need to try again.  We used dynolicious program but will either go to the track or try with the dashhawk.  I will post unless the times are embarrassing.
Offline DickW
« Reply #16 on: June 09, 2009, 11:34:31 PM »
I don't have Dynolicious  or a track close. So I just have to brag about my Dashhawk times even tho I know it is not dead on accurate. But it sounds good. I do have the Solo 3inch Cat and the Solo Mach exhaust. That may help a little.
« Last Edit: June 10, 2009, 08:55:11 AM by DickW »
« Reply #17 on: June 10, 2009, 12:09:29 AM »
I'll have to run a Dynolicious 0-60 in my Sky and see what I get now
 :award:
Offline DickW
« Reply #18 on: June 10, 2009, 02:02:20 PM »
What phone platform are you using. There is a Dynostorm for the Blackberry Storm phone on Verizon. I have Verizon and it would be much cheaper for me. Dynostorm is the same as Dynolicious made by the same company. I would like to compare the results of Dynostorm and Dashhawk.
« Last Edit: June 10, 2009, 02:07:58 PM by DickW »
« Reply #19 on: June 10, 2009, 02:10:24 PM »
Anyone try using the Aeroforce gauge to check 0-60?  I am tempted to try it.
« Reply #20 on: June 10, 2009, 04:03:41 PM »
i suck at launching so those accellerometer things stink for me. i'd rather do a "street start" rolling
for road course driving, 0-60 is not that interesting, because you don't really launch. i'm most interested in my 20-120 speed :)
