Author Topic: Kenwood splash screen  (Read 2367 times)
nomead
« on: July 09, 2009, 05:57:22 AM »
Finally got this working - turned into more of a project than I expected.
A while back I replaced my monsoon with the Kenwood 9140 - very nice unit.
But I wanted to make it mine and continue the theme, so I created the following image based on my avatar:
To get it installed was a pain.
It seems every Kenwood has a slightly different procedure to get to the config screen that allows you to set the "OEM Image".
For this unit it is:
1. hold down the "SRC" and "Volume down" buttons.
2. press the reset key with a paperclip (hole in lower left corner of unit's face).
3. install USB key with properly sized image (480x234)
4. once that completes it is not obvious, but you need to hit the reset again.
5. at this point the unit is still in standby, so go to the src screen and select the radio tuner.
Offline chuckdoc
Re: Kenwood splash screen
« Reply #1 on: July 09, 2009, 08:25:50 AM »
I know Joe and I had a really hard time doing this on my Kenwood.  Most of the info on the internet and the manual was wrong.  We finally got timebandit image installed but you are right, it is a pain.
My KappaPerformance Mod Page
nomead
« Reply #2 on: July 09, 2009, 11:28:19 AM »
Yeah, but the results are worth it!
Hopefully this will save the next person the hassle.
« Reply #3 on: July 10, 2009, 09:07:09 AM »
Thanks for the post.
« Reply #4 on: July 10, 2009, 12:54:52 PM »
its slightly different on the 8120
but close enough
