Author Topic: Distance debate Miles vs NM  (Read 20910 times)
Offline TecSolOnt
Re: Distance debate Miles vs NM
« Reply #25 on: July 26, 2009, 03:26:51 PM »
 Try living in a country where you spent most of your life in a school system that talked feet , lbs and fahrenheit then decided to switch to metres, kilograms and centigrade after you had learned all of that. I was just about out of high school when we decided to switch to the metric system to align with the rest of the world, course someone forgot to tell the U.S..
 Then throw in that I live right across the border from the U.S and watch their weather forecasts and TV programs  most times. I still can't figure out liter per 100 km for mileage,  use mile per gallon  and can't ever quite get what 85F equals in C without doing the math in my head which is way to much work....   OH :ca:
Offline TecSolOnt
« Reply #26 on: July 26, 2009, 03:38:12 PM »
KWhale you had the essentials of the issue correct on the Gimli Glider incident where a 767 had to glide to a landing as it ran out of fuel , it was a little more complicated though as this explanation from Wiki discusses ....and I thought Fahrenheit to Celsius and back was hard  :idk:
http://en.wikipedia.org/wiki/Gimli_Glider
At the time of the incident, Canada was converting to the metric system. As part of this process, the new 767s being acquired by Air Canada were the first to be calibrated for the new system, using litres and kilograms instead of gallons and pounds. All other aircraft were still operating with Imperial units (gallons and pounds). For the trip to Edmonton, the pilot calculated a fuel requirement of 22,300 kilograms (49,000 lb). A dripstick check indicated that there were 7,682 litres (1,690 imp gal; 2,029 US gal) already in the tanks. In order to calculate how much more fuel had to be added, the crew needed to convert the quantity in the tanks to a weight, subtract that figure from 22,300 and convert the result back into a volume. (In previous times, this task would have been completed by a flight engineer, but the 767 was the first of a new generation of airliners which made this position redundant.)
A litre of jet fuel weighs 0.803 kg, so the correct calculation was:
7682 litres x 0.803 = 6169 kg
22300 kg – 6169 kg = 16131 kg
16131 kg ÷ 0.803 = 20088 litres
Between the ground crew and flight crew, however, they arrived at an incorrect conversion factor of 1.77, the weight of a litre of fuel in pounds. This was the conversion factor provided on the refueller's paperwork and which had always been used for the rest of the airline's imperial-calibrated fleet. Their calculation produced:
7682 litres x 1.77 = 13597 'kg'
22300 kg – 13597 'kg' = 8703 kg
8703 kg ÷ 1.77 = 4916 litres
Instead of 22,300 kg of fuel, they had 22,300 pounds on board — only a little over 10,000 kg, or less than half the amount required to reach their destination. Knowing the problems with the FQIS, Captain Pearson double-checked their calculations but was given the same incorrect conversion factor. All he did was check their arithmetic, inevitably coming up with the same erroneous figures.
« Reply #27 on: July 26, 2009, 03:46:54 PM »
I'm guessing you're slightly younger than my parents (they graduated in 69)... :) I think the conversion happened right after they got out of school, so I grew up with metric in school. But ya, the thermostat in our house was F, so I knew that 70F = 20C (approx). MPG still makes sense to me... Most fo the time, I weighed myself in lbs (except in school and at the doctor... they always used kg)
Oh, and the VERY rough and dirty temp calc is that 70F = 20C... and 5 degrees C change from that is about 10F... so 25C is about 80F, 30C is 90F, 10C is 50F... it starts to break down at the extremes (for instance, this would say that 0C is 30F, which is close), but it gives you a rough idea.
Offline Geos GXP
« Reply #28 on: July 26, 2009, 06:56:44 PM »
Canada went metric in 1976, The question I have despite the fact that they are taught strictly metric in school ask any kid their height and weight and the answer is always in feet and inches and pounds?? :ca2:
I still convert everything to standard measurements to understand it. All building materials are also still sold in the standard system!
2007 Black GXP 5 Speed All options except OnStar
« Reply #29 on: July 26, 2009, 07:32:10 PM »
Well, according to Wikipedia, the metification started in 72... but ya, i think signs and stuff changed around 76
I would suspect that most kids talk in feet/inches 1) because their parents did and so that was used at home and 2) the USA media (and I'm thinking of sports as a major factor here, though it's a factor in a lot of stuff). We're just entering a time now where the parents would be raised with metric in schools, so it'll be interesting in 10 years aor so to see what the kids are using day-to-day
Offline baconbits
« Reply #30 on: July 26, 2009, 07:35:01 PM »
In cubic water measurement the definite winner is the Metric system ..1000 litres = 1 cubic meter = 1000 kg..1 litre= 1000  ml  and so on..kinda beats the amount of drams in a hogshead..even after 33 years of metric I still drive in MPH  though around here it's more how many hours are you away from your destination
Offline KWhale
  • Playing with my
« Reply #31 on: July 26, 2009, 10:53:37 PM »
I was in grade 4 (for the first time) when they switched to metric, so I had another 3 years of learnin that new system, and it didn't help me either.  Pretty much like TechSol, I grew up in Windsor, just across the river from Detroit, so everything was F and Feet (say that last part fast).  The only advantage of still being in school was now I know both systems, but prefer F over C (86 sounds waaay warmer than 30) and prefer Kilometers to Miles for speed (100 sounds waaay faster than 62).  Forcing us to use metric is pretty funny sometimes, like some of our groceries will come from the US which are all in pounds.  The US folks would see a sale on grapes, 4lb box $5.  We see a sale on grapes 1.81kg box for $5.  It loses something in the translation it seems.
I actually thought the US passed into law the conversion to the metric system before we did (Canada doesn't do a lot of decision making on it's own).  It's pretty obvious it never happened, but does anyone know what happened to that law and why the conversion never went ahead in the US?
« Reply #32 on: July 26, 2009, 11:29:05 PM »
Well, I grew up outside Vancouver, so near the border as well...
Ya, I was reading a bit about this. The US did indeed pass a law in the early 70s... The fun part I've learned about the USA since i moved down here... states != provinces... Carefully read the name and take it to heart. United States of America... it's basically 50 little countries (each of which have very different laws a lot of the time. The criminal code isn't Federal, unlike Canada.) that agree to be nice to each other... trying to do anything on a national level is.. difficult... My understanding is that many of the states just flat out refused to spend the money to switch over signage, etc (some had started, and ended up having to switch em back)
