Author Topic: How much torque can the auto trans take  (Read 16811 times)
Offline wawa
« on: July 30, 2009, 10:57:35 PM »
Hi everyone,
How much torque can the stock GXP auto trans take before I need to upgrade the internals.
Thanks,
Dave - Wawa
09 wicked GXP
Offline Filipp
Re: How much torque can the auto trans take
« Reply #1 on: July 30, 2009, 11:21:27 PM »
Think I saw someone post saying the auto trans was strong enough for 400-500. Forgot exact # though.
« Reply #2 on: July 31, 2009, 05:41:52 AM »
I do know that if you get the GMPP upgrade with the auto you get 325 lb feet of torque but if you have a manual you get 340.
I would assume that's because of a limitation of the tranny. Maybe not a hard limit but a limit as to where it will operate reliably. Just a guess on my part.
« Reply #3 on: July 31, 2009, 06:02:18 AM »
I believe it is 550, can't remember where I saw it though.
Offline chuckdoc
« Reply #4 on: July 31, 2009, 06:33:36 AM »
The reason for the difference in torque is do to drive train loss, it is not scaled down at the flywheel, just a mater of physics.
I am running a crap load of torque and no problems to date.  No way to get accurate dyno results due to reasons someone else can explain.
The answer will come from the track, just this has been a really bad summer for me, hopefully I will be back in shape soon and can make a trip to the strip.
My KappaPerformance Mod Page
« Reply #5 on: July 31, 2009, 07:37:39 AM »
It is the same auto used in a Colorado 4X4 pick up truck, so I doubt you will ever have an issue with it. It is a very tough auto, and the problem on the dyno Chuck was speaking of is caused by the stall converter, there is no way to lock the auto into 4th to get a good reading. Chuck we have missed you, hope everything gets better.
« Reply #6 on: July 31, 2009, 01:29:23 PM »
gminsidenews.com says the following, but I am not sure how accurate this is
Hydra-Matic 5L40-E Transaxle
Type: five-speed rear-wheel-drive, electronically controlled automatic overdrive transmission with torque converter clutch.
Engine Range: 1.8L-3.6L (gas or diesel)
Max Gearbox Torque: 494 lb.-ft.
Weight: 182 lbs.
Assembly Site: Strasbourg, France
Applications: Cadillac SRX, Pontiac Solstice, Saturn Sky, Opel GT, Daewoo S2X
The site says that the Colorado uses the following AUTO:
Hydra-Matic 4L60-E/4L65-E
Type: four speed rear-wheel-drive, electronically controlled, automatic overdrive transmission with torque converter clutch.
Engine Range: 2.8L-6.0L
Max Gearbox Torque: 600 lb.-ft.
Weight: 163 lbs.
Assembly Site: Toledo, Ohio
Applications: Chevrolet Colorado, Trailblazer, Silverado, Tahoe, Avalanche, Suburban; Cadillac Escalade; GMC Sierra, Yukon, Yukon XL, Canyon, Envoy Denali; Hummer H2, H2 SUT, H3; Saab 9-7x
Here are the MANUAL specs just for comparison, you can see here is where it says we share the same transmission with trucks.
Aisin AR-5
Type: rear wheel drive, five-speed manual transmission.
Engine Range: 2.8L-3.5L
Max Gearbox Torque: N/A
Weight: 107 lbs.
Applications: Chevrolet Colorado, GMC Canyon, Hummer H3, Pontiac Solstice, Saturn Sky
SOURCE: http://www.gminsidenews.com/index.php?page=trans_guide
« Reply #7 on: July 31, 2009, 07:31:40 PM »
I like how the Aisin doesn't include our engine size(s) in the specs.
Offline wawa
« Reply #8 on: July 31, 2009, 08:26:38 PM »
wow, those are great numbers for the auto trans..
Thanks
Wawa
Offline chuckdoc
« Reply #9 on: August 01, 2009, 11:11:01 AM »
Thanks jim, it has been slow with my back but it now only
hurts in am.  I finally broke down and took some
meds.  I will never tell back patents again that it is a
mental problem.
« Reply #10 on: August 01, 2009, 12:16:19 PM »
I found this interesting explanation that sounds right
http://forums.land-and-sea.com/showpost.php?s=4e8464e50b528b6c55dfaefb747ed368&p=2006&postcount=3
« Reply #11 on: August 02, 2009, 08:17:06 PM »
Thanks kennysabarese for posting.  Great points made in the article.  Definitely a good read!
