Author Topic: I am going 27lbs on Friday with Trifecta Tune  (Read 45305 times)
Re: I am going 27lbs on Friday with Trifecta Tune
« Reply #100 on: September 10, 2009, 06:31:33 PM »
I want to hold 28 psi and see what that does with the upgraded wheel.
However I need to get in touch with the Tuner in Miami that has a Dyno and then him and Vince can schedule sometime to work with the tune and my car.
Offline U4EA
« Reply #101 on: September 10, 2009, 06:37:55 PM »
I know you have been waiting for this for a long time.
Offline DirtyMike
« Reply #102 on: September 10, 2009, 07:16:43 PM »
LV, let me know when, where, ect.  Really want to see this!
« Reply #103 on: September 10, 2009, 09:21:49 PM »
LV. Very curios to see what he can do with your turbo wheel!
Offline kwtoxman
« Reply #104 on: September 10, 2009, 09:56:59 PM »
Can you tell Vince the VE, flow rate (or whatever it is called) that the upgraded wheel is capable of and then have him check the data logging on the dyno runs to get the correct boost that corresponds to that #?
Congratulations LV! You were one of the first with the upgraded wheel and blazed a path that interests many. I hope you start to see some notably bigger #'s. I think trifecta is a great choice to move forward. Good for you.
Are you going with select-a-tune?
This is going to generate a lot interest!
:ca2:
Offline U4EA
« Reply #105 on: September 10, 2009, 10:18:54 PM »
If his #s come out good, BTF is going to need to stock up on wheels.
Wonder how the stock clutch is going to hold up?
« Reply #106 on: September 10, 2009, 10:22:32 PM »
He's got the cheapest price so far. But at least two other vendors have them out there.
« Reply #107 on: September 11, 2009, 04:33:05 PM »
I talked to Luis he is the tuner in Miami and he will be talking to Vince.
The flow rate if I remember the answer from BTF is 38lbs/mn.
I will let people know when it will be schedule.
One thing I want to make clear is my setup was already Tune by RANDY & DAVE from DDM.
At present it is very easy for me to do 23psi sustain and not give the car that much throtle.
I would love to have DDM latest tune to see how much more improvements they have made from the original tune they did on my car in Orlando.
The reason I am looking at Tifecta (Vince) is because of the increase in boost and want to see if the larger wheel can sustain 28-29 psi.
Offline kwtoxman
« Reply #108 on: September 11, 2009, 05:28:44 PM »
The boost is most related to how much air you move. With the larger wheel you should be able to boost higher to 28 PSI or more and do it with less turbo effort/spin.
Therefore AFAIK you should be able to push more PSI with less effort and no issues on the turbo or engine.
:ca2:
« Reply #109 on: September 12, 2009, 07:06:57 PM »
T
That is what I am hoping since it does this now with the tune from Randy and Dave from DDM.
I believe as you mentioned 28-29 psi should not be a problem, will have to wait and see once the tune is done.
So far no response from Luis and Vince.
CJ Krause
« Reply #110 on: September 12, 2009, 10:13:48 PM »
Vince has been working on a Ion Project the last couple days and has been around the phone very little.
things should be alot better on Monday.
« Reply #111 on: September 13, 2009, 07:01:53 PM »
I e-mailed Vince all kind of information on my car.
I included a lot of information from BaldTurboFreak, hoping Vince and Rick(BaldTurboFreak) talk.
BTF has posted 322RWHP/360 Torque using a Cobalt SS and the larger wheel at 20psi.
CJ Krause
« Reply #112 on: September 13, 2009, 08:03:03 PM »
Cobalts are getting some crazy #s
i think the largest i have seen is 405 WHP and 430 WTQ or something close to that
