Author Topic: Sound deadener at the MD. Mod Meet  (Read 39913 times)
Re: Sound deadener at the MD. Mod Meet
« Reply #50 on: September 22, 2009, 08:55:41 AM »
He has 3 canapies and a screened one
« Reply #51 on: September 22, 2009, 09:53:21 AM »
I think there will be enough of us to throw DDM out of the garage if we team up, I have a 12'X12' pop up but it doesn't fit in the Solstice very well. If it rains we can all pitch in a buy Joe another one, they aren't that expensive at Wally World.
Offline Rudeboy
    • Sound Deadener Showdown
« Reply #53 on: October 02, 2009, 08:43:09 AM »
I have a steel one, had it for 20 years very handy tool.
( Jim )  Its easier to use a Plastic popper no matter what color then to use steel and have to touch up Paint scraps on Auto Body parts,and as for a roller Hope yours does have a motor on it
« Reply #54 on: October 02, 2009, 08:52:47 AM »
I have panel popers in plastic, but mine are a macho black :)  I also ordered a roller.
What do we need to scrape the old sound deadening from the floor?   Putty blades?
(Critter) Would be nice if someone designed a putty knife that has a heated blade"you still have a week" start with a 9v storage battrey with hot wire on blade and ground lead on behind the handle    :idk:   :worms:
« Reply #55 on: October 02, 2009, 08:54:58 AM »
Propane bottle?
« Reply #56 on: October 02, 2009, 08:57:08 AM »
I have both steel and pink plastic, never scratched anything it is a rounded very smooth finished steel, it's a Mac tool, long ago in a galaxy far far away I was an installer of all things automotive and electronic, hard to believe that was 25 years ago.
The people doing installs will have a much easier time of it, I will be doing the back and floors while you guys do your doors, we can use my panels as a template and maybe someone not doing an install (Bobby? Critter?) can cut the panels from the templates ahead of time, first person to do doors can be used as a template too. If we get all of the stuff cut and don't have to stop and measure every piece it will go MUCH faster. I think doing this as a group will work really well for everyone.
Offline Rudeboy
« Reply #57 on: October 02, 2009, 09:02:49 AM »
An alternative to heat and putty knife that should work very well on the stock deadener is dry ice. Freeze the stuff and give it a whack and it should shatter off cleanly. Could save a lot of time if a few people are planning to remove the asphalt stuff.
« Reply #58 on: October 02, 2009, 09:14:21 AM »
LN2 would probably be even faster...
« Reply #59 on: October 02, 2009, 09:17:07 AM »
Sounds like that might be a "cool" idea Don, I wasn't going to remove the old only for the time saving, but if there is a quick easy way I am up for it. Joe is there any place near you to get dry ice? I can get it at the grocery store near me. Here is a directory of Dry Vendors in 410 area code MD. http://www.dryicedirectory.com/results.asp How much would we need?
« Reply #60 on: October 02, 2009, 01:05:37 PM »
It came up 412 area code, I re-entered 410 and there 20 vendors, but they are all up in the general Baltimore-Annapolis area.
« Reply #61 on: October 02, 2009, 04:56:22 PM »
Any place that sells welding supplies will have dry ice.
« Reply #62 on: October 02, 2009, 06:50:44 PM »
 enlighten me, Why?
« Reply #63 on: October 02, 2009, 08:09:13 PM »
That's a good question and one that I can't answer with any authority. I do know that any place that sells welding gasses and supplies will have dry ice. I can't find any information as to why that's the case other than the dry ice blasting machine.
http://www.nu-age.com/machinesales.htm
It would provide non destructive cleaning of parts before welding.
A few years ago my son had to do a science project for school. He did some research and found the project that he wanted to do and it needed dry ice to work. A Google search at the time indicated that you could get dry ice and anyplace that sold welding gases and supplies. We called a couple local suppliers and they all carried dry ice. When the place that we went to so we could pick it up and they found out it was for a science project, my son got it for free.
Couldn't beat the price.    :D
« Reply #64 on: October 02, 2009, 10:30:20 PM »
Area codes here are 240, 301, 443, 410  Waldorf is 45 minutes away but perhaps there are location close to others.  There is one in Laural MD also.
« Reply #65 on: October 03, 2009, 02:10:25 AM »
1 WEEKKKKKKKKK!!!
« Reply #66 on: October 05, 2009, 01:42:48 PM »
They sell it in the grocery store here for use in coolers (Shoppers Food), not sure any there do or not.
