Although one might think so, there really are no down sides with the GXP/Z0K bars. They are only 20% stiffer than the FE3 bars on the GXP and RL. If the hypothetical bump was so significant that it upset the car, it would do so with ANY bars under the car. I have been playing with a spreadsheet that calculates spring/wheel rates as well as bar rates. Being fairly confident that I have the measurements correct, the front bar is nearly 10 times stiffer than the rear. The best bet is to install the REAR GXP/Z0K bar, keave the FE3 front bar in place, and see how you like it. One thing you'll need to know is that this puts a Redline in Street Prepared per SCCA Solo rules.
As for EVERY car coming with VERY STIFF bars, that is a different thing !!!! REALLY stiff bars are not such a good thing as they will not let the suspension work well. REALLY stiff bars are used on REALLY serious race cars to tune the suspension that have REALLY stiff SPRINGS. An RL is not in that league. Get a rear bar if the classing issue is not a concern, and if you want a less neutral car then get the Z0K front bar as well.
Confused yet ?!?!?!?!
