Author Topic: Motorized License Plate- Modified for Lowered GXP  (Read 10629 times)
Offline DragonSolGXP
Re: Motorized License Plate- Modified for Lowered GXP
« Reply #25 on: October 15, 2009, 12:12:47 PM »
I got nabbed on Sunday for driving without a front license plate. I'm in Ontario. I had washed my car and forgot to put it on and took a ride out to my brothers in the next town...Brampton for those in the area... got nabbed by a "squad" of OPP perched on the on ramp from the 410 to the 407. He didn't buy my excuse and gave me a $110 ticket.
« Reply #26 on: October 15, 2009, 12:23:42 PM »
I run front plates on all my stuff (except one special collector car plate that is transferable which only has a rear) except this one - if you can tell me where to mount it without blocking 1/3 of the rad opening, I'll put it on.....doesn't make much sense to me to attach it under the opening as you couldn't see it anyway.
Had even more fun with an old Triumph TR-2 I used to own - no bumpers, so finally hung it off the front sway bar with a couple of hose clamps.  Obvisously should have moved it to the horizontal high performance position for this track session!
2007 BMW Z4M coupe
Recently sold:
« Reply #27 on: October 15, 2009, 03:29:44 PM »
That's pretty cool.
You need to add theme music to it when closing it
I'm glad I don't have to worry about that.
GO PA!!!
Offline PureXTC
« Reply #28 on: May 17, 2010, 03:37:04 PM »
I am likely moving to Ontario in the next year and will have to display a front plate :( Does anyone know if there a way to wire this to the ignition so it pops up when you turn the engine on and hides itself when you switch off?
Pure 2008 GXP 5-Speed, Air, Chrome Wheels, Splash Guards, Sport Pedals, Monsoon, On-Star & XM
Performance Mods: Superchips Tune, K&N Drop-In, Dejon BOV Spring, Kappasphere Re-Bar
Appearance Mods: MGP Caliper Covers, De-badged (except arrowheads), Kappashield, Kapparoo, Lil Chromies, Chromed Valve Stem Caps, Stubby J Series Antenna, AirBag Light Cover
« Reply #29 on: May 17, 2010, 03:43:45 PM »
Should be pretty simple. I'm not sure how the device retractible plate works, is it a toggle switch or momentary switch.  If it is a toggle, then install a 2 relays, one for plate up using the accessories circuit to control the plate.  second for plate down on batt power.   Key on, plate up, key off, retract.
Offline Spedee
    • Spedee
« Reply #30 on: May 17, 2010, 07:55:17 PM »
The button on the remote must be pushed and held down until the plate is fully retracted. Same for the other direction.
« Reply #31 on: May 17, 2010, 08:17:09 PM »
Spedee,
Great pics!
