Author Topic: What did you do to your Kappa today!  (Read 1272317 times)
0 Members and 17 Guests are viewing this topic.
« Reply #1200 on: July 11, 2010, 10:07:16 AM »
Yay!!  Glad you have it back...why don't you get Norm's hood?  I think he has a new one for the Sky.
« Reply #1201 on: July 11, 2010, 10:16:54 AM »
I have heard rumblings that this exists but have never seen pictures. And, what is the wait on it?
I am thinking about going with the RKSport Hood. If you haven't seen it, I posted pictures of it in this thread...  http://www.kappaperformance.com/forum/index.php?topic=4888.0
« Last Edit: July 11, 2010, 10:26:21 AM by SHiNY »
Offline shabby
« Reply #1202 on: July 11, 2010, 10:35:19 AM »
Good luck on the install. Have you seen my guide about the Kirkeys?
I did see it, after doing some measurements the included brackets will just need some minor modifications to work with the sliders.
Offline shabby
« Reply #1203 on: July 11, 2010, 07:56:29 PM »
Seats are in... wow what a difference they make, feels like a totally different car.
« Reply #1204 on: July 12, 2010, 07:33:20 AM »
Rolling in style.
« Reply #1205 on: July 12, 2010, 07:38:52 PM »
Shabby,
How much weight did you save by using these?.
Offline shabby
« Reply #1206 on: July 12, 2010, 10:16:53 PM »
New seats are 15lbs each, old ones were aboot 30lbs so 30lbs of total savings.
« Reply #1207 on: July 12, 2010, 10:46:01 PM »
How much lower do you sit in it?
Offline shabby
« Reply #1208 on: July 13, 2010, 04:05:32 PM »
Currently its at the middle notch and at the stock ride height, if i would of used the stock brackets as is i would of been sitting an inch higher.
« Reply #1209 on: July 13, 2010, 04:18:18 PM »
Thread for installation???
Offline shabby
« Reply #1210 on: July 13, 2010, 05:16:32 PM »
Installation is pretty straight forward, at least for these seats since the width at the mounting point was identical to the width on the sliders. The supplied brackets were L shaped, i simply cut the bottom of them, flattened them since they were angled a bit, drilled some mounting holes and made some clearances for the slider arm/spring and bolted them in. Simple really, but cutting steel wasn't, should of made some aluminum brackets.
If you want to sit a bit higher than stock you can simply add some aluminum L brackets onto the supplied brackets, again they need some mounting holes and clearances made for the slider arm.
Here's a closeup of the bracket, you can kind of make out my half assed attempt of making the clearances for the spring/arm. I'll probably redo them in aluminum later on.
« Reply #1211 on: July 14, 2010, 01:23:15 PM »
Called JPM and my new shifter is on its way.
Yesterday the DROID . . . tomorrow my new shifter! :D :yay:
« Last Edit: July 14, 2010, 01:35:43 PM by smartin »
Offline G8TR
« Reply #1212 on: July 14, 2010, 01:26:52 PM »
Welcome smartin to the world of Droid! :thumbs:
Offline JimmyBaja
« Reply #1213 on: July 14, 2010, 01:34:03 PM »
In a world that doesn't, Smartin does.  :lol:
« Reply #1214 on: July 14, 2010, 01:35:19 PM »
Thanks, G8TR and JB -- I think! :D
« Reply #1215 on: July 14, 2010, 09:11:57 PM »
Well, not quite my Kappa, but met Scott Pruett at the Houston Airport yesterday.  Really nice guy!  He was on his way home to Sacramento.
Offline Brazen17
« Reply #1216 on: July 15, 2010, 12:40:03 PM »
Took it in to the dealership to get the turbo bypass valve replaced.  Wish me luck!
« Reply #1217 on: July 15, 2010, 12:42:02 PM »
Good luck!
Offline Brazen17
« Reply #1218 on: July 15, 2010, 12:44:21 PM »
Offline Brazen17
« Reply #1219 on: July 15, 2010, 09:17:24 PM »
Doesn't sound good.  Dealership needs to keep it over night and call higher HQ tomorrow for guidance.  Didn't get into the nuts and bolts yet but they said it had a bunch more codes since when it was there three weeks ago.  Basically they said it was calling just about every sensor bad.  Oh boy, here we go.
« Reply #1220 on: July 15, 2010, 09:35:11 PM »
Installed AEM Tru Boost - boost controller and gauge along with Aeroforce Interceptor scan gauge.
« Reply #1221 on: July 15, 2010, 09:41:17 PM »
Norm, take the time to start a new thread about the gauges and tell us about them.  :thumbs:
« Reply #1222 on: July 16, 2010, 08:55:38 AM »
Yes, Norm. :thumbs:
I will be installing my shifter today. :)
« Reply #1223 on: July 16, 2010, 09:08:17 AM »
Not sure 2.0 can accommodate a boost controller since the waste gate is electronic. Not unless you have pcm software like HPTuners.
The scan gauge plugs into OBD port. I know some wanted more info than the DIC displays. I just have the vitals now and will play more next week.
Offline DirtyMike
« Reply #1224 on: July 16, 2010, 02:55:06 PM »
New spec 3+ non sac clutch and fly wheel came in and going on soon! Also ordered norms sky side fenders....
