Author Topic: What did you do to your Kappa today!  (Read 1269574 times)
Offline IBDRINKEN
  • Donkey Master
« Reply #2475 on: February 23, 2011, 06:11:38 AM »
shit lets see i have the following ones egt,boost,oil temp, fuel pressure, oil presssure. I have no where elses to mount, Im going to have to take out one of those. What do you think.
13.5@101.90
320HP 358 Torque
Kappa Intake
JPM Shifter, Center Console
DDM Intercooler
AEM Water/Meth Injection
« Reply #2476 on: February 23, 2011, 06:36:53 AM »
You monitor the low pressure fuel, right?
I would give up on Oil Temp, oil pressure is showing oil temp indirectly.
Offline IBDRINKEN
  • Donkey Master
« Reply #2477 on: February 23, 2011, 06:43:31 AM »
well its fuel pressure to be exact, good call on the oil temp
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
« Reply #2478 on: February 23, 2011, 06:48:17 AM »
Also I think you can convert oil temp into water temp as far as I know.
Fluid temp sensors are pretty much same and because you have digital gauges than you don't have a value range to limit you in a different range than you want.
Offline IBDRINKEN
  • Donkey Master
« Reply #2479 on: February 23, 2011, 06:54:16 AM »
so basically all I would have to do is just buy the new sender and hook it up the oil gauge. Let me ask this Im looking at the senders and not sure which one to get. Here is the link to them
http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=111/category_id=245/home_id=59/mode=prod/prd111.htm
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
« Reply #2480 on: February 23, 2011, 07:02:08 AM »
I think sender is same, only fittings might be different, why to buy a new sender if you already have one from your oil temp?
I think you should research about our stock water sender to find out fitting sizes.
Also another idea, why don't you tap your gauge on the stock water sensor?
Offline IBDRINKEN
  • Donkey Master
« Reply #2481 on: February 23, 2011, 07:04:21 AM »
I think sender is same, only fittings might be different.
Thats a great idea and makes more sense. I will do some searching and see what I can find. Thanks again for your help.
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
« Reply #2482 on: February 23, 2011, 07:09:44 AM »
No problem mate, I love to help this community, you helped me with gauges in the past too, I was just trying to return the service.
Offline Yogi
« Reply #2483 on: February 23, 2011, 12:36:01 PM »
I'd be concerned that 2 instruments on one sender might interfere with each other.   The sender works by varying the resistance across 2 wires.  Any circuit that you add in parallel with the ECM will have some resistance, and the ECM has some resistance too.  So the ECM or the gauge will be reading the total resistance of the sender + the other instrument.  It may throw off your readings.
Why not eliminate fuel pressure instead?    :idk:
2008 Saturn Sky Red Line
2.0 Turbo LNF
5 Speed Manual
Snowflake Wheels
Monsoon Sound System
Leather Seats
Offline IBDRINKEN
  • Donkey Master
« Reply #2484 on: February 23, 2011, 05:19:27 PM »
Its a tough call..
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
« Reply #2485 on: February 24, 2011, 10:56:16 AM »
Avoided a seat belt ticket. Whew!
Drove to work this morning and normally I put my seat belt on right after I back out. But everything was clear and then the couple of lights I go through were green. So as I was putting it on, I see a cop at the intersection. He follows me through the residential area that I cut through. I follow the speed limit and stop at the stop sign. I'm sure that he ran my plate. Thankfully, it's a secondary infraction here so he turned and went to the fire station and left me alone. :yay:
Saw another cop as I came down through another residential area. Luckily, I was still driving appropriately. Must be end of the month quota time. :D
« Reply #2486 on: February 24, 2011, 11:27:06 AM »
Smartin, don't let me down.
first we buckle up, then we turn the ignition on.
correct???
« Reply #2487 on: February 24, 2011, 11:29:05 AM »
Drove it in the snow with Michelins PS2, parking in our crowded small spots is far easier now  :rofl:
« Reply #2488 on: February 24, 2011, 11:36:47 AM »
correct???
Not always. ;)
Offline smarty
« Reply #2489 on: February 24, 2011, 11:45:18 AM »
Ordered some enhancements from Norm for the GXP!!! :yay:
Still undecided on the Coupe, but that Rotrex Supercharger looking mighty tasty... :drool:
2008 Gxp Aggressive Mods: GMPP CAI and Tune; DDM Race Backbone, Probeam, Led Hood and Trunk Lights and Lambo Doors; Molded flaps, Solo Street Race Exhaust, Norms F430, winged rear diffuser, Joe's side marker light mod with leds, Windblade, with the Bull Dawg!...
Offline Yogi
« Reply #2490 on: February 24, 2011, 01:33:08 PM »
I washed it, waxed it and put a set of Dunlop Direzza Z1 Star Specs on it!  WOO HOO!!   :yay: :yay:
SCCA Solo National Tour comes to Houston on March 19-20.  Can't wait to see how the Star Specs do on the course!   :drive:
2.0 Turbo LNF
5 Speed Manual
Snowflake Wheels
Leather Seats
« Reply #2491 on: February 24, 2011, 02:23:15 PM »
correct???
Nope, it's turn the ignition on, then buckle up while the car is warming up. :cheers:
« Reply #2492 on: February 24, 2011, 03:01:54 PM »
:agree: Except I got out into traffic before it warmed up! ;)
« Reply #2493 on: February 24, 2011, 03:10:31 PM »
Mine is sitting all warm, dry and clean in the garage.
gonna wait until the snow melts, it rains to get rid of all the remaining salt and is dry again before he will come back out.
« Reply #2494 on: February 24, 2011, 07:03:26 PM »
Yeah mine too fortunately, or unfortunately...   :(
Offline S.P.
« Reply #2495 on: February 25, 2011, 08:57:20 PM »
Spent the latter half of the day adjusting my windows to close the gaps at the weatherstripping. Hoping this will reduce the wind noise a little bit.
« Reply #2496 on: February 25, 2011, 10:11:16 PM »
I took mine for a Short ride after work . Then My key fob stop working and a dealer fixed that one a year ago.
 "My Auto up-down Window Gadget came today ."
« Reply #2497 on: February 25, 2011, 11:36:05 PM »
Ordered lots of fun in a DDM kit today!
« Reply #2498 on: February 26, 2011, 07:27:00 AM »
Taking her in for free service and oil change. At least one good thing came out of the dealerships closing... free stuff!
« Reply #2499 on: February 26, 2011, 08:52:22 AM »
No wonder we have turbos failing, you trust that they put in the correct oil?
