Author Topic: What did you do to your Kappa today!  (Read 1264971 times)
« Reply #3550 on: April 26, 2011, 09:25:10 AM »
My turbo cover is ready to go as should my wheels be by the end of the week.
http://www.kappaperformance.com/forum/index.php/topic,6846.msg99038.html#msg99038
Offline duckSol
  • Onward through the fog
« Reply #3551 on: April 26, 2011, 10:16:46 AM »
Looks good. Tempts me to put up pics of the one Va_Sky gave me that I have to fit to the Solstice.
Decided yesterday SLY was fully dried out from his top down interior bath at the eye doctors :gaah: :lol:
« Reply #3552 on: April 26, 2011, 10:34:55 AM »
Stupid question. I have 49k miles on my car and have never done anything to the engine. The dealer and book do not have any recommendations for "real" maintenance until 100k miles. Any recommendations?
I was thinking about changing spark plugs, and obviously checking belts and hoses.
What about motor mounts? I have heard these can be troublesome on occasion, I have looked in the maintenance manual and understand their location, only quesiton is, are they difficult to get to? is it worth the time and money to get them check also?
To keep this what I did today, I drove in to work and hoping the heavy fog burns off so I can wash my car this afternoon. LOL!!!
VERY NICE WORK SLYBOB AND G8TR!!!
« Reply #3553 on: April 26, 2011, 10:48:59 AM »
factory spark plugs are supposed to live about 80K miles. it wouldn't be a bad idea to change them though, if you don't mind spending the money. or at least have them checked.
Offline G8TR
« Reply #3554 on: April 26, 2011, 11:52:39 AM »
Cleaned the MAF sensor and the K&N filter. Car seems to be running smoother.
« Reply #3555 on: April 26, 2011, 12:07:06 PM »
Drove it to work again with the top down, 70 degrees.  I haven't changed the plugs yet and I'll roll over 70,000 miles on the way home.  Still running great on the Westers Tune since 5k miles.
« Reply #3556 on: April 26, 2011, 03:29:14 PM »
You are truly blessed Joe!  Wow, over 70,000 miles, man, I just hope and pray I can drive Miss Red Eagle that long...
Offline G8TR
« Reply #3557 on: April 26, 2011, 08:20:01 PM »
You have to get it out of the garage to put miles on it. :poke:
« Reply #3558 on: April 26, 2011, 09:03:10 PM »
Played a bit with the Kappa.
My mechanic told me that the electrical connector for the cooling fan is resting on the LV bar (he was replacing the fan for the second time due to a faulty control module; can't replace the module alone).  So I tweaked the control module (rotated it down to max) and pushed the bar backward all the way.  That gave me a couple millimeters but I could see daylight between them.  I think that will work.
Then I saw that the Dejon IC pipe (cold side) was rubbing in a couple places.  Pulled it toward the back, rotated it relative to the manifold connector, zip ties, and put rubber trim around the edges on airbox bracket and hood hinge bracket.
I feel better now :)
« Reply #3559 on: April 26, 2011, 11:20:54 PM »
New wheels are ready to be picked up at the powder coaters!
http://www.kappaperformance.com/forum/index.php/topic,6852.msg99173.html#msg99173
« Reply #3560 on: April 27, 2011, 07:36:13 AM »
If it is a mark on the top, the rubbing takes place when the hood is closed and it hits the hood hing on the front edge, you need to to loosen the clamp on the front of the IC and shove the pipe farther into the rubber so that it sits lower.  that will stip it from rubbing.
« Reply #3561 on: April 27, 2011, 07:42:03 AM »
Yeah, got my replacement new black headlight from Crate (all four mounting taps are present), and shipped back the defective one their dime.  Started claying & polishing the vert, will follow-up with Best of Show wax.   The Griotsgarage polisher is making the task so much easier.  :buff:
Also ordered more micro fiber towels, polish, new-car interior scent, and  leather :devil: interior scent.
« Reply #3562 on: April 27, 2011, 09:54:08 AM »
Can't do that, the bottom of the pipe bend is already pretty close to the airbox bracket.
« Reply #3563 on: April 27, 2011, 10:37:11 AM »
The front edge of the airbox bracket under the pipe needs to be cut off to allow the pipe to site lower.
« Reply #3564 on: April 27, 2011, 11:37:37 AM »
Or just don't use the brackets on the ic pipe at all.
I don't have them on my dejon pipes and have had no issues in 2 years
« Reply #3565 on: April 27, 2011, 02:46:31 PM »
Already did.  Well, I had to trim down the back edge.  I was talking about the steel bracket below the plastic "lip" that needed trimming.
My Dejon pipe doesn't have any bracket, whether welded or otherwise.  I also removed all the bracketry associated with the stock IC pipe.
« Reply #3566 on: April 27, 2011, 02:47:15 PM »
BFH?
« Reply #3567 on: April 27, 2011, 02:48:49 PM »
BFH?
Hahahaha, I'll wait till I got open-element air filter (wife has been complaining that the car was too quiet), it will allow me to get rid of the brackets.
Offline DickW
« Reply #3568 on: April 27, 2011, 03:41:05 PM »
A couple days ago my GXP got real loud. Took it to the muffler shop. The passenger side tail pipe had pulled out of the clamp connecting it to the muffler. much quieter now.
Offline IBDRINKEN
  • Donkey Master
« Reply #3569 on: April 27, 2011, 03:50:42 PM »
Loud is good right...lol
13.5@101.90
320HP 358 Torque
Kappa Intake
JPM Shifter, Center Console
DDM Intercooler
AEM Water/Meth Injection
« Reply #3570 on: April 27, 2011, 03:52:34 PM »
Did you hit anything on the road?
Offline idkfa
  • Violent Jain
  • mostly harmless
    • Make
« Reply #3571 on: April 27, 2011, 04:59:50 PM »
That'll teach you to neglect your muffler bearings.
Offline IBDRINKEN
  • Donkey Master
« Reply #3572 on: April 27, 2011, 05:18:36 PM »
and blinker fluid..
13.5@101.90
320HP 358 Torque
Kappa Intake
DDM Intercooler
Offline DickW
« Reply #3573 on: April 27, 2011, 06:19:06 PM »
 No. I guess my muffler bearings needed greasing. My blinker fluid is up to the mark on the blinker dipstick.
« Reply #3574 on: April 27, 2011, 06:31:40 PM »
Actually it sounds as your muffler bearings were over greased thereby reducing the emodial coefficient. Glad you aren't having problems with the blinker fluid. A leak in that system isn't good.
