Author Topic: What did you do to your Kappa today!  (Read 1264622 times)
0 Members and 12 Guests are viewing this topic.
« Reply #3800 on: May 15, 2011, 08:03:41 PM »
Working on a custom mount for my Ultragauge today.  It will attach to the left of the steering column placing the UG above the right switch stalk.
I probably won't take pics, 'cos nobody cares about my mods.  (Sob!)
I only read the forum for the pictures (oops I mean articles) :D
« Reply #3801 on: May 15, 2011, 08:08:50 PM »
I want to see that TomatoSoup!! What's an Ultragauge?
Offline DickW
« Reply #3802 on: May 15, 2011, 10:31:47 PM »
Offline Aspenrose
« Reply #3803 on: May 16, 2011, 12:16:27 AM »
^^^ That's not good, no oil light & how many miles sense the last oil change.
Mike
had it changed right before we left on vacation, odds are the tech only put in 2 quarts, the odd noises turned out to be the missing oil, not the throw out bearing, amazing how quiet it became once it had the full compliment of Mobil 1...the owner will be getting a letter, and will know that if their screw up causes any residual issues, they will be paying some one else to make it right...makes me sick to think I was screaming down Hellbender, and assorted other mountain back roads, plus all the highway miles for hours every day, on 2 qts..suffice it to say, I won't trust them to touch any of my vehicles, ever again. CEL for the cam pos sensor quit going off, also.
« Reply #3804 on: May 16, 2011, 12:19:44 AM »
Aspen rose,
I'm not sure if that's good news, or bad.  Glad it was a simple fix.  Hope nothing comes of it.
Offline Aspenrose
« Reply #3805 on: May 16, 2011, 12:37:22 AM »
Aspen rose,
me too, me too. it ran great for the 400 miles home, impressed by the fact (so far) that it took that abuse, and seems ok. but it gets mighty boring running for days with no music playing, just so I could listen for inappropriate noises!
Offline J_Bond
« Reply #3806 on: May 16, 2011, 01:42:08 AM »
new iridium plugs installed.  DEI heat-wrapped my K&N intake, installed with heat shield. I cannot believe how massive the stock intake setup is!!! shaved a pound or two off the front end! lol
       Installed lightweight battery from WERKS.
  Put her on the DYNO.  Dyno-Tuned her with HP Tuner software, increased timing, increased rev limiter, made 200ft lbs torque to the wheels.  Still cannot believe she made 200ft lbs!!!  Dyno tuning is by far the best way to do this motor rather than non-specific tunes.
Radiator flush coming this week with DEI coolant and water-wetter.  Considering installing a lightweight radiator.... anyone know of any vendors with one that will fit?
Dimpled and slotted rotors installed with ceramic brake pads. Painted my calipers black.
Installed Koni shocks on Eibach pro springs.... LOVE this setup.  solid, quieter than stock and the ride height is PERFECT.  Swapped out the stabilizer links all-around for preventative maintenance. Wish I would have upgraded all my bushings while it was all apart :(   Lubed the old stuff.
Though I realize I could make more power with an exhaust setup, it's just not in the cards, I HATE the ricey sound of a 4-cylinder.
I will admit, the stock exhaust being drowned out by my cold air intake setup sounds AWESOME. sounds like a street bike.  I think I will get a hi-flow cat and tune on the Dyno again though. Shouldn't increase the noise too much.
Oh yeah, I also installed my custom painted black billet front grill and removed the chrome bird-beak from the front end. Looks much cleaner.  Also installed my Redline black headlights, and put H11 LED's in my foglights.
As for the future of my exterior:  Norm's Viper hood, Norm's fenders and painting that stupid silver window frame BLACK!  :)  oh, and paint my door handles black too.  Chrome is so 1995.....
WERKS lightweight battery
Dyno-tuned ECM by HP-Tuners
SOLO Single Catback exhaust
SOLO header
SOLO High Flow Cat
Energy suspension bushings
Koni shocks
Pro-Kit springs
EBC slotted dimpled rotors
Hawk Ceramic pads
BLACKED-out everything...
Redline headlights
Gutted trunk
« Reply #3807 on: May 16, 2011, 08:45:46 AM »
had it changed right before we left on vacation, odds are the tech only put in 2 quarts, the odd noises turned out to be the missing oil, not the throw out bearing, [...]
I always check the dipstick if someone else changes the oil in a car of mine.  Admittedly it's usually just to confirm the new oil is clean (and has actually been changed) but you'd catch under or overfill issues too.
« Reply #3808 on: May 16, 2011, 08:50:53 AM »
J_Bond you did all that today??? :)
wow, i see you ve been busy!!!
« Reply #3809 on: May 16, 2011, 08:54:34 AM »
Damn Mel if it wasn't for bad luck,  let's hope no damage was done.  Cams are moved by oil pressure, so the CEL going out is a good sign.  Anyone you trust to pull the valve cover and take a good look at the top of the head, cams and lifters?
Offline JimVonBaden
« Reply #3810 on: May 16, 2011, 09:22:29 AM »
Absolutely, never trust anyone but yourself!
Even then, trust but verify! :lol:
Jim :cool:
« Reply #3811 on: May 16, 2011, 09:56:08 AM »
:agree: I stay with my car at all times when work is being done.
Offline J_Bond
« Reply #3812 on: May 16, 2011, 11:15:08 AM »
I am a relentless mod-whore.....  :)
SOLO header
SOLO High Flow Cat
Koni shocks
Pro-Kit springs
Hawk Ceramic pads
Redline headlights
Gutted trunk
Offline Yogi
« Reply #3813 on: May 16, 2011, 11:37:23 AM »
  ...............Also installed my Redline black headlights, and put H11 LED's in my foglights............
J_Bond, How do you like the H11 LEDs in the fogs?     :huh:  I didn't know that they made an H11 LED!  Where did you get them?   :idk:
2008 Saturn Sky Red Line
2.0 Turbo LNF
5 Speed Manual
Snowflake Wheels
Monsoon Sound System
Leather Seats
Offline G8TR
« Reply #3814 on: May 16, 2011, 11:39:34 AM »
Just got back from Kennedy space center.
« Last Edit: May 17, 2011, 01:18:49 PM by DeepBlueGXP »
Offline Yogi
« Reply #3815 on: May 16, 2011, 11:42:09 AM »
Aspen Rose - Glad to hear that you found your problem!  If it were mine, I would get an oil analysis pronto to look for any high metal content in the oil.  That would be a good indicator of any damage to bearings and journals.
Good luck!   :thumbs:
2.0 Turbo LNF
5 Speed Manual
Snowflake Wheels
Leather Seats
« Reply #3816 on: May 16, 2011, 11:55:05 AM »
[attachment=1]
NIIIICE! :thumbs:
Offline Yogi
« Reply #3817 on: May 16, 2011, 12:04:29 PM »
[attachment=1]
Great pic, Ric!  I wish that I could've been there!
2.0 Turbo LNF
5 Speed Manual
Snowflake Wheels
Leather Seats
« Reply #3818 on: May 16, 2011, 12:27:52 PM »
Wow!  What a GREAT picture!
I'd love a full-res copy of that (hint)
« Reply #3819 on: May 16, 2011, 12:42:56 PM »
Ric, Great pic. I haven't been to a launch in years. As a matter of fact my last on was on board a sub of the coast of Cape Canaveral back in the day for a night launch... Thanks again!!!
« Reply #3820 on: May 16, 2011, 02:47:48 PM »
Lucky! Always wanted to see a shuttle launch down there. Had to content myself with the online feed, same as always.
« Reply #3821 on: May 16, 2011, 02:55:48 PM »
Which was it? Day or Night?  Are sure you were really there? Most people could at least remember if it was day or night....
Offline G8TR
« Reply #3822 on: May 16, 2011, 03:32:41 PM »
This one was at 8:56 this am, not sure when Bobby's was. It was very overcast and gray. I have before pics that almost look black and white. Needless to say the shuttle really lit up under the clouds and made it look almost like it had been launched at dawn/dusk. I have plenty more pics and a video.
TS
I will send a high res, just pm me your email. Taken with 5D Mark II, 21mp.
G8TR
« Reply #3823 on: May 16, 2011, 03:43:06 PM »
TS
G8TR
Thank you!  PM sent.
« Reply #3824 on: May 16, 2011, 03:49:02 PM »
saw the launch live on Nasatv. it was amazing!!
