Author Topic: What did you do to your Kappa today!  (Read 1404642 times)
0 Members and 18 Guests are viewing this topic.
« Reply #450 on: March 15, 2010, 10:15:41 AM »
Is now without a cat along with Kappasphere the boost build noticeable quicker. Getting rid of hi-flow cat only increased volume level slightly as the KS1 middle does a good job of ridding drone/resonance. I was considering replaceing the muffler with straight pipe for weight savings but when you add up tubing, clamps, and hangers the muffler was only slightly more weight with allot less noise.  Also replaced replaced a stripped hose clamp on a very important oil line that goes through drain plug access hole.  :)
Norm
« Reply #451 on: March 15, 2010, 11:22:12 AM »
Wed, Thr, Fri - forcast calls for 60+ and sunny, any guesses on what I will be driving?
« Reply #452 on: March 15, 2010, 11:39:18 AM »
Rain hasn't stopped so decided to buy LED for Fender Blinker MOD and for the map lights. Working on getting all the Footwell Lighting MOD parts together. Boy, the mods are piling up, Now all I need is for all my parts to show up so I can get to work.
Later this week is expected to be in the mid fifties and low sixties to get the car out and detail it, install mods, and hopefully get my "Stripes" package for install.
Should the car be with or without wax for decal installs???
« Reply #453 on: March 15, 2010, 12:33:21 PM »
I believe without wax, you could wash it with dishwashing soap which removes all the wax.  But then you need to start from scratch again building it back up.
Use a lot of soapy water both on the body and the decal placing it in place and then you squeege to get the water and air out from under it.
« Reply #454 on: March 15, 2010, 01:18:23 PM »
Just as a (slightly) dissenting view I've seen it recommended to wax first - at least before clear-bra.  It helps protect the paint during install and also makes it easier to remove if you should need to.
Of course if you want best possible adhesion and will never want to remove, then probably without wax is best.  But remember, vinyl does not last forever, especially if out in the sun a lot.  In 5-10 years, if you keep your car, you may want to replace the decals :)
« Reply #455 on: March 15, 2010, 02:13:43 PM »
I know U-238 put on lowering springs this weekend with Ben L at Larry's place.
« Reply #456 on: March 15, 2010, 02:35:09 PM »
Yep, and now I'm having fun dodging potholes, roadkill, and speedbumps.
« Reply #457 on: March 15, 2010, 03:46:28 PM »
That's why I'm driving my truck, I'm looking at a good 9" before I have to worry about bottoming out.
« Reply #458 on: March 15, 2010, 04:24:05 PM »
Did my free oil change this weekend before the parade. I have 3 more to use before the end of the year. This is claimed as warranty work even though it's been out of warranty for 20,000 miles. :D
Offline jonymac
« Reply #459 on: March 15, 2010, 09:11:28 PM »
Today I got my quad LEDs to relocate my mirror map lights to the windshield surround.  Test fitted them tonight - not completely happy with them yet.  I ordered the last Gentex 50-26A in stock on the planet and am waiting for it to come in - it has Onstar, compass, auto dimming, temp, but no map lights.
Replaced the trunk bulb with an LED bulb.
Worked some more on my car computer and researched wheels and tires with Goat today.  My stock rubber is at 46k miles and I really want 19" rims.  Looking at 19x8.5 Bright Sil w/Polished 1" Lip O.Z. Superleggera III 245/40ZR19 front, 19x9 Bright Sil w/Polished 1.5" Lip O.Z. Superleggera III
275/35ZR19 rear on Continental ExtremeContact DWS tires.
Got my 7" DMO touchscreen calibrated and researched finding a replacement piano black piece for the Sky center console for when I hose the first one cutting it up for my screen install...
I will be adding a TPMS system to the wheels and tying it to my car PC using a custom built USB based TPMS computer - more to follow on this...  Geekworks...
Here is the TPMS app I am working with in Centrafuse (envision the code to convert metric to imperial...):
As soon as I make sufficient progress, I will start a thread on this.
« Last Edit: March 15, 2010, 09:35:12 PM by jonymac »
Performance Mods
- Wester’s Race Tune
- Fujita CAI
- Dejon Intake TB Elbow
- Sprintbooster
- DDM Race Backbone & ProBeam
- Z0K Rear End
Other Mods
- Demoneyes
- Rain Sensing Wipers
- Flash2Pass
- Sound Deadener
« Reply #460 on: March 15, 2010, 09:17:44 PM »
Very nice jonymac. Looking forward to the thread!
Offline GaryDN
« Reply #461 on: March 15, 2010, 10:27:45 PM »
finished up the heated seat install and installed the isimple gateway for the ipod.  Its nice having the dashboard back where it belongs, lol
2009 GXP Wicked - all the toys I could find
2007 NA Deep - Traded in 5/13/09
« Reply #462 on: March 16, 2010, 03:06:04 PM »
I took the Sky to work today and will drive home with the top down for the first time in a long while.
Weather Rocks today in eastern PA
Offline jonymac
« Reply #463 on: March 16, 2010, 04:43:53 PM »
WOOHOO!  {Giddy}  I ordered an electromagnetic rear parking sensor system that - get this - doesn't require drilling the back bumper!  Coming from England - should be here next week.  Will start a thread on this when it comes in.  Top down drive home too with the heated seats warming on low - nnniiiccceee.....
« Last Edit: March 16, 2010, 06:31:08 PM by jonymac »
Performance Mods
- Fujita CAI
- Sprintbooster
- Z0K Rear End
Other Mods
- Demoneyes
- Flash2Pass
- Sound Deadener
« Reply #464 on: March 16, 2010, 05:56:19 PM »
I wrapped my down tube off the turbo. If you don't have a shield wrapping the exhaust aid rod the turbo helps increase spool up response. Since my Hahn Turbo does not have electronic waste gate like the RL/GXP so it helps quite noticeably. And when I washed it today I popped the hood and spray down the engine with some simple Green. Since it's a daily driver this winter there was quite a bit of salt and dirt.
Norm
« Reply #465 on: March 16, 2010, 08:34:31 PM »
Washed and waxed mine today. Need to get under the hood with a damp rag and a vacuum cleaner still, and the interior is still a mess, but the car is looking happier.
« Reply #466 on: March 16, 2010, 09:02:24 PM »
Washed and clay barred Lindsey (including the top with 303 Protectant Cleaner) in prep for removing swirls and  redoing the water sealant on the roof.  The water soaks right into my top so I know it needed to be re-protectant to the roof again.
This will be a long week of detailing and polishing and sealing, etc.My rally stripe decals should be here in a few weeks so, I just need to keep her clean and safe until I can get them installed.
Six more mods this month to complete and I will be all set to go for April. Then two more at the Meet.
My personal thanks to all of you "pros" out there helping an electrician do mechanical work.
« Reply #467 on: March 17, 2010, 10:27:27 PM »
Dusted the interior and cleaned the leather. Started work on cleaning the engine compartment.
« Reply #468 on: March 17, 2010, 10:44:43 PM »
I Gave Louise a good bath Cleaned her Wheels and Treated the Top. Then Took her out for a little driving Lesson. Now we're getting ready to Leave for Florida .Will be back around 30th March.
              :drive:         :dancing:      :dancing:      :dancing:     :dancing:        :drive:
« Reply #469 on: March 18, 2010, 08:15:53 AM »
Yesterday, what can I say...
Go-N-Def, your system for polishing and waxing it GREAT. I re-washed, clay barred, polished, polished again, glazed, show shined, and sealed Lindsey...
She looks like liquid white paint.
I have gotten nothing but compliments since I got her done. Now if only I can get the feeling back in my right arm after hand doing all that work.
Today will be footwell lighting install, wheels & rims, leather care, trim protectant, final engine cleaning, with one more coat of sealant. I love the 65 degree weather. I could do this all the time.
The cleaning bug has definitely bitten me. OCD cleaning actually!!! LOL
« Reply #470 on: March 18, 2010, 08:16:59 AM »
1 LIL NDN,
Have a safe trip!!!
Offline SolNut
« Reply #471 on: March 18, 2010, 01:26:52 PM »
Installer said a few days in the SUN will make it 100%   :cool:
Steve
 :drive:
http://picasaweb.google.com/lh/photo/P-W9MaM1FvSUb77x4Z6XJA?feat=directlink
Offline DickW
« Reply #472 on: March 18, 2010, 01:47:39 PM »
Put 4 Conti dws on. :yay:
« Reply #473 on: March 18, 2010, 03:52:06 PM »
Getting emissions done. It's been difficult.
Offline JimmyBaja
« Reply #474 on: March 18, 2010, 08:28:32 PM »
Installed my new DDM Backbone & did the preliminary work (center hole drilled & right & left sides marked for holes) for the Probeam install which I will finish tomorrow - I wanted to see the difference with the Backbone first & then with the probeam. My 140 mi. round trip commute should do as I have about a 20 mi. stretch each way of country backroads which includes a few twisties & rough roads.
Much thanks to the folks at DDM for getting them to me so quick, I ordered on-line Sunday, it was shipped Monday & arrived Wednesday. Outstanding!  :thumbs:  :thumbs:
