Author Topic: Help with Sound Deadener  (Read 7703 times)
Offline dwdgraysol
« on: November 18, 2009, 11:57:44 AM »
I know I seen a post that had pictures and instruction on how to install the sound deadener
from sound deadener showdown , but I can not find it down, also I reminder seeing a post
that had the the packages for the different kits(doors,floor, rear wall etc.) with prices. I
differently want to do this so I like to find this info again.
2008 n/a sly auto,
DDM Works stage II SC.
Offline redragon
Re: Help with Sound Deadener
« Reply #1 on: November 18, 2009, 01:48:14 PM »
Try this link.
or just type in sound deadener on search.
http://kappaperformance.com/forum/index.php?topic=2450.0
Offline dwdgraysol
« Reply #2 on: November 18, 2009, 02:10:03 PM »
Thanks Redragon thats the one I have been searching for. :urock:
2008 n/a sly auto,
Offline redragon
« Reply #3 on: November 18, 2009, 05:50:22 PM »
No problem.
Any time. :cheers:
« Reply #4 on: November 19, 2009, 10:10:55 PM »
Welcome to the forum Redragon, thanks for helping out...
Offline redragon
« Reply #5 on: November 20, 2009, 11:45:12 AM »
Thanks Deepblue
My pleasure, will do what i can to help in any way.
 :cheers:
Do a lot of lurking, lots of good information here.  Sure has helped me on a lot of ideas.
« Reply #6 on: November 21, 2009, 10:09:18 PM »
Just finished my trunk!  Exhaust is totally in the rear now, no rattles, and a lot cooler in the trunk!!
Offline redragon
« Reply #7 on: November 22, 2009, 10:02:30 PM »
How was the install? Pretty easy and was the carpet hard to reinstall?
Thinking of doing that just wondering how difficult it is going to be.
« Reply #8 on: November 23, 2009, 12:43:12 AM »
If your Doing the install alone the complete cabin takes a Full good long Day . Seats,rear waterfalls and everything conneced has to come out. Oh and disconnect the Battrey.Hardest part is geting it all ready.
Offline TecSolOnt
« Reply #9 on: November 23, 2009, 09:51:33 AM »
  Doors are a pain, lots of trimming to do.  You have to pull everything apart in the cabin so that takes a while, less fussy than the doors though.  Don sent me the pieces pre cut to cover the holes in the door though , don't think he is doing that now. Trunk is actually pretty easy compared to the rest, it does get a little tight getting the one piece trunk mat back in.
 I did it over 3 days, probably took 10-12 hrs of work with a helping hand from a neighbour. I didn't disconnect the battery , nothing happened as a result. Glad I did it now its behind me, car sounds solid.
Offline dwdgraysol
« Reply #10 on: November 23, 2009, 04:26:16 PM »
My plans are to do all of the interior (doors,rear waterfall area,floors and the rear panels behind the doors).
I think I will get the whole kit do the trunk area at a later date. :thumbs:
2008 n/a sly auto,
« Reply #11 on: November 23, 2009, 07:37:59 PM »
Agree,  That's what I did.  Also - as a tip - you can break the install up into two stages...
1. The doors (or even each door separately).  When you've cut one door, use the MLV as a template to do the other.
2. The cabin, floor and back wall.  You need to pull everything out, so may as well do these at one shot.
Then if you ever DO do the trunk, that'll make the 3rd (4th) stage
Offline solstice-d
  • SYNN
« Reply #12 on: December 22, 2009, 12:46:22 AM »
where did you guys get this sound deadener???
2006*COOL*SOLSTICE
POWDER COATED RIMS
C.F INTERIOR
DEBADGED
A.E.M: COLD AIR INTAKE
GXP PARTS: DUAL EXHAUST, FE3 SUSPENION
SOLO-PERFORMAANCE:HIGHFLOW CAT, SHORTY HEADER
KAPPASPHERE: REBAR
DDMWORKS: RACE BACK BONE
NORMS FIBERGLASS: DUAL REAR DIFFUSER
ASAP.DIGITAL.IMAGING: SLOTTED BACK UP LIGHTS,SIDEMARKERS,THRID BRAKE LIGHT,TURN SIGNAL/FOG LIGHT COVERS,TRANSFORMER OVERLAYS,TEAM SOLSTICE T-SHIRTS
« Reply #13 on: December 22, 2009, 01:01:59 AM »
They got it from Rudeboy.  He's a supporting vender on this site.  Here's his homepage:
http://www.sounddeadenershowdown.com/cgi-bin/index.cgi
« Reply #14 on: December 22, 2009, 07:59:16 AM »
Rudeboy can but a package together for the Solstice.
« Reply #15 on: December 22, 2009, 08:28:51 AM »
With the additional weight of doing a complete sound deadening install, do you think I could off set noise/weight  of catlessness and muffler delete? My K1S muffler probably weighs best part of 35 lbs.
Norm
« Reply #16 on: December 23, 2009, 09:56:22 AM »
I run a catless setup on my car, and the sound deadener did a nice job toning down the interior resonance.  Is it gone?  No.  Is it much better?  Definitely.  Road noise and rattles are gone!  Stereo sounds amazing!!!!  For the money, it's a homerun mod!
« Reply #17 on: December 23, 2009, 10:01:20 AM »
Then carpet in the trunk can be a bit of a pain.  It is pre-molded carpet.  The additional sound deadening material makes it tight, but with some tweaking, it goes back in place.  Interior carpet was really simple to put back in.  Everything went back really snug.  Don't forget, you are removing the stock GM "sound deadening", so this creates a little more room on the floors.  The stock stuff is horrible and actually peeled right up using my hands and a scraper with minimal work.
« Reply #18 on: December 23, 2009, 10:39:05 AM »
dwdgraysol   Jonymac was the 1st to have it done by Don. Check his Post from the Begining and what his Wife had to say about sound.It does make a differance when driving.
« Reply #19 on: December 23, 2009, 11:39:27 AM »
spicy, you have mufflers with your catless setup?
Norm
« Reply #20 on: December 23, 2009, 11:51:56 AM »
... you are removing the stock GM "sound deadening", so this creates a little more room on the floors.  The stock stuff is horrible and actually peeled right up using my hands and a scraper with minimal work.
Actually, in my case it was a royal pain to get the stock asphalt up/off.  May be an age thing (the older, the easier).  For me that was the worst bit of the whole install.
It's not difficult, but it IS time consuming.  TechSolOnt's estimate is pretty much right on the money.
« Reply #21 on: December 23, 2009, 01:52:12 PM »
TomatoSoup   In hot weather its a real Bi%^h in the cooler weather we peeled it up with our fingers . When Don and I did mine he used a heatgun / I used a b-tank torch .
Maybe we should have used Dry Ice to make the metal cold.
« Reply #22 on: December 23, 2009, 02:12:52 PM »
I just had two resonators in the rear...that's all.
