I just wanna know which wire it is!
J1 - 45 & J1-46 on the ECU J1 is from the other thread. Can anyone confirm?
J1-45 is a gray wire and is labeled "5V REF 3".
J1-46 is a tan wire and is labeled "LOW REF".
I believe these are feeds TO the crank position sensor which is located on the left rear corner of the block above the the starter.
J1- 35 is a yellow wire and is labeled "CKP SENS SIG".
This one should be the actual position sensor signal TO the ECU.
The crank position sensor has three wires at the plug of the sensor.
Looking at the entire thread, the guy who posted the pin out also corrected himself towards the end for a 2.4 set up. The important thing is that he said he was "assuming". Additionally, he read the wiring diagram incorrectly for the 2.4. Honestly, I am not trying to be a smart ass or appear to be a know-it-all, but the poster on the BB may be a bit off on his info. I am looking at factory wiring diagrams on line at Mitchell. He was correct on the LNF voltage signals TO the sensor, but had not provided the signal path BACK to the ECU. Ecliptech does not show an option for picking up the crank sensor to fire the shift light. Just trying to help.
