Author Topic: B*tch is dead  (Read 13423 times)
B*tch is dead
« on: December 30, 2008, 10:21:02 AM »
 :( Went to drive Bix to work this morning, she has been sitting since the Sandy Point trip.  Not enough juice to even unlock the doors.   :gaah: First time in three years this has happened.  Will have to charge her back up and take her out tonight.  Does anyone know if we have a wet cell battery that requires a periodic check of the fluid level?  From what I can see under the lambo hinges and power steering resevoir it looks like it has filler caps.  :nuts:
Offline chuckdoc
Re: B*tch is dead
« Reply #1 on: December 30, 2008, 10:23:52 AM »
John, you might also want to pick up one of those things that hook up to the cigarette lighter with a 9 volt battery, then when you (if you) need to replace the battery, it saves all your settings.
I am looking for one myself as last time the dealer disconnected mine, it took a long time to reset everything the way I liked it.
My KappaPerformance Mod Page
Re: B*tch is dead
« Reply #2 on: December 30, 2008, 10:25:44 AM »
3 years, the battery could be due for replacing.  I haven't check the top of the battery.
Re: B*tch is dead
« Reply #3 on: December 30, 2008, 10:45:36 AM »
Wow, better check mine then. Sorry to hear this Critter. Don't you have to take off the fender to change the battery in these?  :gaah:
Offline chuckdoc
Re: B*tch is dead
« Reply #4 on: December 30, 2008, 10:50:16 AM »
Taking the fender off is not as hard as you think.  Joe has had mine and his off a bunch of times.  It is just 8 or 9 bolts with one hard to get to.  (have to open the door half way)  unless you have lambo doors.
Chuck
Re: B*tch is dead
« Reply #5 on: December 30, 2008, 11:41:18 AM »
Oh. Well, for those of us that don't take off our fenders on a regular basis, it's a challenge.  :D
Offline GregGXP
  • Go NAK3D
Re: B*tch is dead
« Reply #6 on: December 30, 2008, 11:56:02 AM »
That just means you need to start doing it more...  :D
2008 GXP, Mean
Solo RCD: Norms Diffuser: JPM Shifter:
DDM Backbone:
Westers Tune - To Be Installed
NAK3D is like a box of chocolates
Re: B*tch is dead
« Reply #7 on: December 30, 2008, 12:06:17 PM »
Guess so.
Nice to see you, Greg!
Re: B*tch is dead
« Reply #8 on: December 30, 2008, 12:12:24 PM »
smartin, is that the fender on yours that needs to be fixed?
Re: B*tch is dead
« Reply #9 on: December 30, 2008, 12:18:28 PM »
It's my right side fender that needs some TLC.
Offline GregGXP
  • Go NAK3D
Re: B*tch is dead
« Reply #10 on: December 30, 2008, 01:51:20 PM »
Guess so.
Same here SM...  I swear one day I am going to make one of the meets.
2008 GXP, Mean
DDM Backbone:
Re: B*tch is dead
« Reply #11 on: December 30, 2008, 02:03:53 PM »
You better!
Re: B*tch is dead
« Reply #12 on: December 30, 2008, 08:15:28 PM »
She started right up after an hour on the charger, the only thing I lost was the time on the radio, everything else was still there including the radio settings.
Time to start looking for a gel cell
Offline Whip
  • Global Moderator
  • Air Force Retired
Re: B*tch is dead
« Reply #13 on: December 30, 2008, 10:33:07 PM »
And you notice that Chuckdoc stated "Joe has had his and mine off".  So, Joe has the busted knuckles, not our resident surgeon.
GMPP Stage II Tune
Deepblue turn signal mod
Burl wood dash
Re: B*tch is dead
« Reply #14 on: December 30, 2008, 11:55:56 PM »
Offline GaryH
Re: B*tch is dead
« Reply #15 on: December 31, 2008, 11:40:13 AM »
  My car will be 3 years old in June when I make that trip to Denver from Alabama.  I was having thoughts of getting a new battery before the trip.  It's easier (and cheaper) to do things like that at home rather than on the road.
07 Sky
VIN  1745
Magnaflow Quad Tip exhaust
Tail of the Dragon 2008
Denver 2009
Ohio 2010
08 Sky DDM SC stage ll
Solo Mach exhaust
Offline chuckdoc
Re: B*tch is dead
« Reply #16 on: December 31, 2008, 11:48:26 AM »
Hey Whip, I hold the flashlight and usually only shine it in his eyes once an event.  Right Joe.
chuck
Offline Gunnys GXP
  • SEMPER FI
Re: B*tch is dead
« Reply #17 on: December 31, 2008, 12:07:26 PM »
If you don't want to mess with the fender you can pull the wheel, remove the back half of the fender well bolts, the bottom of the fender support arm (so it swings out of the way) and pull it out through there.  Takes about the same amount of time and the fender re-alignment is almost nothing.  My battery died from the climate change during the move east and would not hold a charge after.  That is how I did mine just to see how it went.  both are fairly effortless. Just an alterative option.  I hate that bold in the doorway.  I'm always afraid I am going to slip and chip the paint.
Re: B*tch is dead
« Reply #18 on: December 31, 2008, 12:48:14 PM »
One has the Brains. One has the Brauns.
Unfortunately for Chuck, Joe is both of those "Ones"!!!!
