Author Topic: Service Airbag?  (Read 44591 times)
Re: Service Airbag?
« Reply #50 on: July 21, 2012, 12:22:57 AM »
I got a service airbag message on the dic and the red warning sign between the tacho and the speedo. Passenger airbag is off. During the trip, it went from on to off and then comletely died... I guess i m on for some expenses?bbad sensor?
Re: Service Airbag?
« Reply #51 on: July 21, 2012, 12:59:53 AM »
Check under seat plugs and connectors
Re: Service Airbag?
« Reply #52 on: July 21, 2012, 01:01:33 AM »
Will do so GJ, will also check the fuse, but it seems in most cases has been a bad sensor...
Re: Service Airbag?
« Reply #53 on: July 21, 2012, 02:21:12 PM »
did you have the top down?  Wife in the passenger seat?  Bounce her out of the car?
Re: Service Airbag?
« Reply #54 on: July 21, 2012, 02:32:37 PM »
John   You make it sound like an ejector seat from a James Bond Movie . I though it was an Air bag  ?
Re: Service Airbag?
« Reply #55 on: July 21, 2012, 05:41:57 PM »
Yeap. Yeap. No.
Just the annoying dic red icon and message...
Re: Service Airbag?
« Reply #56 on: July 22, 2012, 12:38:56 AM »
FYI if you're having a red dic issue you might want to go see a doctor and be more careful with the kind of air bags you're hanging around with.
Offline Sky4Two
  • Sky4Two
Re: Service Airbag?
« Reply #57 on: July 23, 2012, 07:04:20 PM »
I've got the same light. Service air-bag. I'm taking it to the dealer. :tool:
Blooper
Offline DirtyMike
Re: Service Airbag?
« Reply #58 on: July 24, 2012, 03:56:26 PM »
Mine showing same thing recently...need time also happened to my sister's gxp last year, bad sensor.. mine is out of warranty so i wonder what it will cost
Re: Service Airbag?
« Reply #59 on: July 24, 2012, 04:11:47 PM »
yeah i m wondering the same thing too... found from local guys it should be smthg like 100 euros... :(
Offline Sky4Two
  • Sky4Two
Re: Service Airbag?
« Reply #60 on: August 22, 2012, 09:13:15 PM »
Dealer ordered and replaced a bad module. 2 hour repair. Under warranty......No Charge
Blooper
Re: Service Airbag?
« Reply #61 on: November 14, 2012, 10:57:14 AM »
 :lol: :lol: :lol: :lol: :lol:
you believe US and Canadian dealerships rip you off?  think again.
how much did the local Opel dealership ask me for to replace the airbag sensor with the bottom seat cushion?
NO, guess again....
2065 euros... meaning $2500 dollars (yes, these are 2 zeros)...
i believe that i will be asking a forum member's help pretty soon in order to get the part from USA
Re: Service Airbag?
« Reply #62 on: November 14, 2012, 12:07:53 PM »
Was that just for the part?  Of course it doesn't take much labor to install either.  If your going to do this you might want to add seat heaters if you don't already have them (how cold are your winters in Greece anyway).
Re: Service Airbag?
« Reply #63 on: November 14, 2012, 12:12:39 PM »
yeap, that was just for the part according to their recent pricelist. of course some people around here replaced the part with 100 euros plus 40 euros labor, which sound already too much.
my reaction was: " no sir, i don't want a used car with airbag, i want the airbag sensor for this car"  :lol:
seat heaters sounds good, but the truth is that we don;t need it around here. i mean, if it snows just a bit during a winter, it's on the news.
top down on the other hand is much more common in Greece (due to the weather)  ;)
Offline Napi
Re: Service Airbag?
« Reply #64 on: March 31, 2015, 10:36:18 AM »
Hey Guys.
I had the same problem, "service airbag" and the passenger airbag always on "off".
Replaced the sensor by myself, but the error remains...
Does the dealer have to "install" the new sensor via tech2? Or sth like that?
Yours,
Napi.
Re: Service Airbag?
« Reply #65 on: March 31, 2015, 11:06:01 AM »
I don't think they have to "install it" in the software but they may have to reset the code, however I am not sure about that.  It could be a system that does a retest and then resets on it's own.  If you don't get an answer by this evening I will try and look it up and let you know.
Offline Napi
Re: Service Airbag?
« Reply #66 on: March 31, 2015, 12:30:53 PM »
Weird thing is though, that the obd-app on my phone told me, there is no code at all...
Re: Service Airbag?
« Reply #67 on: March 31, 2015, 01:00:17 PM »
The error about airbag might not be in ECM (engine computer), that's why you might not see it with OBD reader.
I think is handled in BCM and you can't delete it, the system autochecks everything and if is fixed it will go away.
Offline Napi
Re: Service Airbag?
« Reply #68 on: March 31, 2015, 02:18:33 PM »
Ok. The car had a couple of starts since I replaced the sensor... So maybe it is something else...
Is t possible to clear the bcm by removing the battery lines?!
Re: Service Airbag?
« Reply #69 on: March 31, 2015, 04:07:21 PM »
There is a separate passive restraint controller module, located under the OnStar box IIRC.  Need techII to configure and/or read airbag codes.  And yes you need the dealer to retrain/reset the system when you replace the seat sensor.  (Though some have said that they replaced the sensor without needing a reset - they seem to be in the minority.)
Re: Service Airbag?
« Reply #70 on: March 31, 2015, 05:42:54 PM »
GM SRS system resets itself on startup unlike BMW system.
Re: Service Airbag?
« Reply #71 on: March 31, 2015, 05:53:17 PM »
lcated under the OnStar box IIRC.
Opel GT doens't have OnStar so I don't think Napi knows where to look :)
Re: Service Airbag?
« Reply #72 on: March 31, 2015, 08:55:34 PM »
Napi there are all kinds of DTCs that can be set for the airbags and you will need a proper scan tool to retrieve the codes.
When you replace the seat sensor you will have to set up the new sensor or that will set a code.  Also when you install the new sensor you will have to do a preload test procedure.
A lot of the codes that can self clear will do so after 255 error free key cycle some are 100 cycles, very few are just when the error is not detected.  There also appears to be those codes that can only be cleared with the scan tool.
In your case it looks like you will have to visit a dealer so that you can set up the new sensor and do the test, Tomato Soup appears to be right (don't tell him I said that)
The sensor Tomato soup mentioned is between the seats behind the rear cockpit panel.
Offline Napi
Re: Service Airbag?
« Reply #73 on: April 01, 2015, 12:20:15 AM »
Got that.
Dealer it is.
I will get back to you, when I was able to have a tech2 check done.
Thanks so far! :thumbs:
Offline Napi
Re: Service Airbag?
« Reply #74 on: April 05, 2015, 05:05:54 AM »
Man...
Dealer stated he couldn't help me, because the new tech2 software does no longer include compatibility to the Opel GT...
So it's either driving to the next "center", which I will do in a couple of weeks or buying a tech2 myself...
Is there sone kind of a "cheap version" of the tech2? Like a cable and software for my laptop or sth?
Yours,
Napi.
