Author Topic: Tunnel brace on a coupe  (Read 2409 times)
Offline JimmyBaja
« on: March 04, 2010, 07:23:47 PM »
I was thinking of adding a DDM Backbone & Probeam to the coupe but I'm not sure if the coupe would need/benefit from the Backbone since it has a more upper/roof structure than the vert.  :idk:  Any input on this would be appreciated.
Re: Tunnel brace on a coupe
« Reply #1 on: March 04, 2010, 07:41:24 PM »
I don't think the coupe adds that much more structural rigidity to make the Backbone irrelevant.
The Probeam is for hooking together some of the rear suspension bits, so unless your coupe has a Z0K crossmember, it will also help.
I say go for them both.
Offline Graywolf
« Reply #2 on: March 04, 2010, 10:16:28 PM »
I suspect the DDm backbrace would be beneficial. I have a roll bar in my car which stiffens thinks alot and plan on fabricating one in the future. Stiffer is better than softer
Offline Divingsolo (formely Randy@DDM)
    • DDMWorks - Your total Kappa Performance Solution
« Reply #3 on: March 04, 2010, 10:36:24 PM »
In terms of vehicle rigidity, the coupe is NO different than the Vert.  the roof panel is not structural. The coupe is just a vert with a hardtop bolted to it and a targa top.
Randy@DDMWorks.com
www.DDMWorks.com
« Reply #4 on: March 04, 2010, 10:48:37 PM »
Actually, the coupe is more rigid than the vert but in my jacking experiences with my coupe, I found that it was much stiffer after installation.
The pro beam will benefit all Kappas unless you already have the upgrade beam with the welded channel on it.
