Author Topic: WARNING -- wheel torque with ARP wheel studs  (Read 18985 times)
« on: March 08, 2010, 03:12:09 PM »
If I have argued with anybody about lug nut torque on ARP wheel studs -- here is my apology. I was VERY wrong.
What's all THIS about? VERY good question. When I switched to ARP wheel studs, I used ARP p/n 100-7702, which is a 7/16x20 thread. The factory studs are 12x1.5. Well, I was admonished that my continued use of the factory torque value of 100 ft/lbs was WRONG. THEY were correct and I was WRONG. What happened? The car was on jack stands for new springs and exhaust. When I put the wheels back on, I was having trouble torquing the rear wheels. Confused as to what the issue was, I switched to a different torque wrench. No luck. So, I said to hell with it and kept turning and snapped a couple studs. OOPS. So, I called ARP and they told me that 90-100 is correct for the 12x1.5 factory studs but the 7/16x20 ARP studs should be torqued to no more than EIGHTY ft/lbs.
So -------------- if you have installed, or plan to install the ARP studs, do NOT torque them to factory specs, but rather 75-80 ft/lbs.
« Last Edit: March 08, 2010, 03:24:20 PM by DeepBlueGXP »
Re: WARNING -- wheel torque with ARP wheel studs
« Reply #1 on: March 08, 2010, 04:22:48 PM »
And another valuable lesson is learned the hard way.
« Reply #2 on: March 08, 2010, 05:28:38 PM »
Snapon,
Thanks for the heads up!  Hope the next person reads this prior to snapping a stud!
« Reply #3 on: March 08, 2010, 05:39:43 PM »
D'oh!
« Reply #4 on: March 08, 2010, 05:41:22 PM »
D'oh!
Eggs ACTLY !!!!!!!!!!!!!!!!!  :gaah: :barf:
« Reply #5 on: March 08, 2010, 06:37:49 PM »
Yet another piece of very useful information to put into the memory banks for later retrieval. Thanks Bob for taking one for the team.  :cheers:
Offline Ben L
« Reply #6 on: March 08, 2010, 06:51:35 PM »
Better you snapped it in the shop than in the paddock or, worse, on course.
Live and loin.
« Reply #7 on: March 08, 2010, 07:32:23 PM »
Yeah, you could have easily ended up like this guy. You must remember this video.
http://www.youtube.com/watch?v=jv4m41viy4I
« Reply #8 on: March 08, 2010, 07:33:54 PM »
Live and loin.
Well, there IS that !!!!!!! And that is what I was telling myself.
« Reply #9 on: March 08, 2010, 07:35:40 PM »
Actually, there IS a story about that. But I am STILL seriously skeptical about the idea of ALL the studs breaking almost all at the same time, EVEN on the INBOARD side.
« Reply #10 on: March 08, 2010, 07:39:36 PM »
The story that I heard about that video is that they had the wrong thread on the nuts that they were using. They were able to make torque but when the took her for the run, the nuts pulled off the studs.
I understand that they now use the proper nuts on the studs. (No kidding)    :banghead:
« Last Edit: March 08, 2010, 07:50:50 PM by Sly Bob »
« Reply #11 on: March 08, 2010, 07:41:03 PM »
a bad batch?  or to weak for the job and not up to spec
« Reply #12 on: March 08, 2010, 09:07:31 PM »
American STD (SAE) pitch lug nuts on Metric wheel stud. In other words, they were "stripped" on to the studs.
Offline boardkat
« Reply #13 on: March 08, 2010, 09:32:05 PM »
this is also the story i remember hearing.
that said, we had a local competitor in an SRT-4 ACR that had simultaneous failure of all 5 factory studs on one corner at an event last year.  he's running ARP now :P
'05 Lotus Elise || SS/42
'09 GXP 5MT Sly Coupe #802 - RIP :(
'82 Reynard FF1600 || CM/70
'86 Golf || chumpcar monster
« Reply #14 on: March 09, 2010, 11:07:11 AM »
Somewho I missed this, makes a little more sense now, but I have to agree with Bob, I don't see all 4 coming off at once. at lest not that quickly.  I have had a wheel come off before after a shop only finger tightened the lugs, and that took miles 30 miles or more before I got a shimmy, and as I slowed down to pull over the wheel took off on it's own, never to be seen again.
Offline Ben L
« Reply #15 on: March 09, 2010, 04:02:01 PM »
I remember an SCCA autcross school I went to where a newbie in an M3 Beemer (they use short little bolts, not studs) did not torque his wheels down, and the drivers side front came whistling past my head about 20 feet from me like a Civil War cannonball as it spun off just as he was cranking the turn on the last gate of a slalom.
I never forgot the simple lesson I learned that day.  Torqin' at home is not enough.  Make sure they are torqued before rolling up to the line.
Offline TravisJames
« Reply #16 on: April 02, 2010, 12:15:57 PM »
Hey snaponbob... you seem to be pretty knowledgeable regarding spacers and studs.  I'm going to install a set of 3/16" spacers on all four tires; is this going to require longer studs?  If so, would the ARP p/n 100-7702, 7/16x20 thread be the ones I need?
Thanks!
2008 Black Onyx Red Line
Current Mods:
Westers Race Tune
Dejon Cold Air Intake, Aggressive Red Piping, Intercooler and BOV Spring
GMPP Cat-Back Exhaust
Kappasphere reBAR, KSRDisc (slotted rotors) & Eibach Springs
DDMWorks "Race Version" Backbone, Custom Powder Coated Big Brake Calipers and Stainless Steel Brake Lines
JPM Steering Wheel & Visors
19" TSW Snetterton Wheels
MRZ Engine Covers and Trunk Closeout
Painted Engine Cover
Painted Chrome Front Bumper Grille Insert
Stubby Antenna
Window Tint
« Reply #17 on: April 02, 2010, 12:31:16 PM »
Don't install them if you don't need them, unless they're hubcentric then they're fine.
Offline TravisJames
« Reply #18 on: April 02, 2010, 12:57:10 PM »
They're the 3/16" spacers sold by DDMWorks (http://ddmworks.com/sky/accessories/wheelspacer.html).  Unfortunately I don't have the spacers yet and I don't see anything on their site stating they're hubcentric, they only say they're made specifically for the Kappa platform.  I've been pretty impressed with the quality of products I've gotten from DDMWorks in the past and would be surprised if they were manufacturing these without considering all the fitting/load bearing aspects of design.  Regardless, I would be really interested to know peoples opinions regarding these particular spacers and whether or not I'll need longer studs.
Thanks again!
Current Mods:
Westers Race Tune
Stubby Antenna
Window Tint
Offline Acadian
« Reply #19 on: April 02, 2010, 01:31:39 PM »
Thanks for the heads up snap-on bob.
Critical information that needed to be shared with the rest of us.
Lightweight with no options 2006 stripper ! with added
GXP Z0K SPRINGS, FE3 Bilsteins shocks
GXP Z0K front ant rear sway bar
DDMWORKS stage 2 Eaton supercharger with intercooler
DDMWORKS hi-flow converter and long tube headers.
« Reply #20 on: April 05, 2010, 10:39:28 AM »
James - I ran these (DDM) on the front when I ran the stock wheels with the 4 piston brake kit.  Didn't need them on the rear.  It is a close fit and if you are going to be slaming the car around, I would go with longer studs.
Offline Divingsolo (formely Randy@DDM)
    • DDMWorks - Your total Kappa Performance Solution
« Reply #21 on: April 05, 2010, 06:17:44 PM »
We can supply the proper 12x1.5 ARP longer studs...I don't think we have them on the site, but just give Dave a call or email and he can get you pricing.   I've been running these for over two years now.  You do have to run an open style lug nut with these.
Randy@DDMWorks.com
www.DDMWorks.com
« Reply #22 on: April 05, 2010, 09:13:12 PM »
Randy, the ARP 100-7702 (7/16 x 20) has a .580 knurl. The 12.5 x 20's (100-7708 and 13) has a .508 knurl. http://www.arp-bolts.com/catalog/catalog.html The .508 may be too loose as the .580 is not a real tight fit at all.
BTW, I left a message over the weekend about some braided brake lines. Please let me know.
« Reply #23 on: April 05, 2010, 09:16:09 PM »
With stock wheels, there is roughly a lug nut engagement of 8 turns. A 3/16" spacer will eliminate 3-4 turns of engagement. NOT enough to safely secure the rims. Spacers = longer studs.
« Reply #24 on: April 05, 2010, 09:24:29 PM »
Bob,
Those are not the bolts we are using. The ones we sell have the proper knurl size.
Randy@DDMWorks.com
www.DDMWorks.com
