Author Topic: engine always running rough  (Read 3238 times)
Offline redcomet303
« on: March 19, 2010, 07:34:20 PM »
I have an 07 redline with 12k miles on it. its bone stock. I have had issuses with it running poorly but no codes. also it feels a bit slow. it is hitting 14psi max and dropping down to about 12-13 near redline. I read a post similar to my condition so I unplugged my purge solenoid. the code for it showed up on my second start. but after I unplugged it the car runs smoother and dosnt try to stall everytime i put it in first at a redlight it feels like I have more low end toruqe now. What could be the main issue? I dont want to drive with the cel on forever but Im not going backwards.
Offline Imaj
Re: engine always running rough
« Reply #1 on: March 19, 2010, 09:18:58 PM »
Just a guess...Could be your catalytic converter.
Offline redcomet303
« Reply #2 on: March 19, 2010, 10:10:30 PM »
But why would unplugging my evap purge solenoid fix the issue?
Offline chuckdoc
« Reply #3 on: March 20, 2010, 06:56:12 AM »
I agree with bad cat, there were quite a few of these in 2007.  I also had a similar problem with rough idle and it turned out to be the cam shaft actuator however it did not effect boost.  Eventually you will throw a code.
My KappaPerformance Mod Page
Offline redcomet303
« Reply #4 on: March 20, 2010, 11:04:19 AM »
Ok well I wanted to go catless anyways but is there a service buletin out on it I don't want to deal with the usual dealership run aroud
« Reply #5 on: March 20, 2010, 01:55:24 PM »
Coverage for the converter and Powertain Control Module is 8 years or 80,000 miles, whichever comes first. Shouldn't be an issue at the dealership.
Offline redcomet303
« Reply #6 on: March 20, 2010, 03:41:30 PM »
How do they check the cat? And I called they want me
to being it up to them and hey will alia see if there are any recalls on it.
« Reply #7 on: March 20, 2010, 04:06:56 PM »
They check the cat by doing a back pressure test. There aren't any recalls of the cats that I am aware of. It is however a common problem and not with the Solstice. All manufacturers have problems with cats as they all are of similar design.
Here's a YouTube video that covers the basics.
http://www.youtube.com/watch?v=4QvR5Nqun4g
Offline redcomet303
« Reply #8 on: March 20, 2010, 07:37:14 PM »
I won't be able to bring the car in for about two weeks. Until then I'm goin to leave the purge solenoid unplugged. Is there anything else I can do before then
Offline redcomet303
« Reply #9 on: March 22, 2010, 10:06:29 PM »
http://www.cobaltss.net/forums/showthread.php?t=207984
Same problem found on the cobalt ss website that I am having looks like several of them are suffering to
