Author Topic: Trunk lid won't open  (Read 2892 times)
Offline FixedJoker
« on: March 31, 2010, 11:51:29 AM »
My trunk release button on my remotes or in glove box will not open the trunk. We just installed a amp and speaker box behind the seats. I have pulled the back panels back off and looking for a disconnected wire or something but can't find why it wouldn't be getting power. It doesn't even sound like it trys to release. Any ideas? All other electronics work fine in the car.
Offline FixedJoker
Re: Trunk lid won't open
« Reply #1 on: March 31, 2010, 02:28:28 PM »
Found the problem.   When checking the relay #18 under the hood.   Looked at the fuses and in slot #10 25amp fuse was blown for the trunk.   Replaced the fuse and trunk opens like new.
« Reply #2 on: March 31, 2010, 02:59:22 PM »
just saw this.  Glad you fixed it.  I wonder what blew the fuse.  Thats a first.
Offline FixedJoker
« Reply #3 on: March 31, 2010, 03:15:26 PM »
I'm thinking I must have shared the same ground post on the back wall, as the trunk release when I installed the amp on initial hook up and that must have blew the fuse when I connected the power lead to the battery.
« Reply #4 on: March 31, 2010, 03:20:24 PM »
Ahh, we had another member after putting in sound proofing, found that the ground wasn't hooked up and he had closed his trunk.  I had to remove the left rear wheel, take off the fasteners for the back of the wheel liner and cut a slit in the trunk to reach the T handle to open the trunk.
Offline Dirkdaddy
« Reply #5 on: April 02, 2010, 02:35:26 AM »
My Sky is in my garage and no engine or wireharness, and the paint shop closed the trunk  :banghead:   After looking at manual and using a flashlight, I figured out I could undo the trunk by using a long needlenose to yank the cable since my hooped trim was removed for paint.  I am thinking of installing a long wire or line into the pass compartment and hide behind the bulkhead/waterfall thing in case of emergency I could dig it out and open trunk easier.  I know there's also that release, but this might be easier.   :thumbs:
Offline duramax
« Reply #6 on: April 04, 2010, 12:28:54 AM »
I am thinking about a wire from the latch to inside the waterfall storage compartment. That should be easy to do.
2008 NA Sky Midnight Blue Black Top Black Leather Chrome Wheels Monsoon single disc Vector ECM WR Electric Blue V1 Sequential Turn Signals Pulsing Third Brake Light RL Exhaust Smoke Side Markers That Flash With Turn Signals. GMPP CAI and Splash Guards GM All Weather Mats Butt Plugs 35% Tint GMPP Saddle Bag JPM Center Console Bun Warmers
