After a night running with some V8 Mustangs and a 2010 Camaro SS, i popped some codes after i shut off the engine then restarted. Codes are P0443, P0102, P0030. I lost cruise control. After erasing the codes they dont come back on the first startup, but they do on the second. Ive not noticed anything weird about how the car is running. I've cleaned the front 02 sensor, MAF sensor, MAP sensor, and tightened one of the intercooler tubes that i found loose. The codes still come back. I'm going to disconnect the battery and hope that somehow resets the BCM/ ECM. Right now it seems i'm grasping at straws. Thoughts?
