Ace - The P0455 code can be caused by a few things. I've been researching this for that exact same code on my Durango, and here's what I've learned so far.
#1) - Make sure the gas cap is on properly. If it is, then the cheapest fix of all for this code is a new gas cap.
#2) - If you are the kind of person who squeezes every drop into the tank that you possibly can when you fill up, stop doing that. The overflow fuel is getting into the evap lines and can cause you problems.
#3) - there is a either a hose off, or a hose with a crack or hole in it. This is the second most likely cause, and unless you have the ability to check out all the hoses yourself, it could be the biggest waste of money solution.
I have been living with the P0455 CEL on my Durango dash for about 1 year now. I did replace the gas cap, I am not an over-filler, and I did trace all the hoses I could find. Several hoses were old and weathered and perhaps cracked but I could not find a specific leak anywhere, and all were attached where they should have been. In my case the entire vehicle is worth maybe $4k, I'm not going to throw hundreds of diagnostic dollars at what is essentially a moronic California (no offense GJ) emission standard. If the light really starts to bother you, a little piece of electrical tape should fix that up
