There are 6 wires that need to be spliced from the the push button start module and the passive keyless entry module. 5 of the 6 wires need to be routed over to the BCM in the passenger footwell to be connected. These wires are also approximately 4 ft short (I notified DGD about the deficiency). I utilized the same route for these wires as I did for the flashlogic wires. All wires EXCEPT the light blue wire were routed to the BCM. The light blue wire would normally be routed over there as well for vehicles with an automatic transmission (it gets connected to the BCM connector C1 pin 53). For those of us with a manual transmission I recommend connecting the light blue wire to the clutch safety switch. Pictured in photo 1.
see photo
The clutch safety switch is a 2 pin connector. This one connection is a S.O.B.!!!! There is very little space to disconnect the plug, pull it down, and solder your wire. It is a tight painful, connection to make! I can't remember if I soldered to the purple wire or yellow wire and will need to confirm this one connection at a later time.
