Author Topic: Issue w/6disk Monsoon-2006 Sol  (Read 3735 times)
Offline Aspenrose
« on: May 06, 2010, 03:37:22 PM »
Just now, I had a disk fast forward through several dozen tracks, finally got it to stop at one, after than none of the buttons on the radio except the >> work, would not shut off, etc, none of the buttons on the wheel work, and while it would eject a disk, will not load any. Once all were ejected, it's 'stuck' on FM, and only the volume can be changed on the radio itself, and only can >> to seek the next station upstream. The only thing that shuts it off is removing the key and opening the door. Soon as the door is shut, and key on, it's on again, stuck on FM  :nuts:
Any ideas??
Re: Issue w/6disk Monsoon-2006 Sol
« Reply #1 on: May 06, 2010, 04:19:08 PM »
Pull battery cable, let it sit for 10 minutes or so, reconnect and try again?
Offline KWhale
  • Playing with my
« Reply #2 on: May 06, 2010, 05:00:53 PM »
U238's suggestion is the same as I was going to make.....I was also going to suggest a back-up idea
 :poke: Learn to enjoy FM radio :poke:
Offline Aspenrose
« Reply #3 on: May 06, 2010, 05:01:02 PM »
Will be the first thing I do when I get it home (as long as the rain has not started), thanks
anyway pulling the ECM would accomplish the same thing? (only ask cuz it's easier to do :D )
« Reply #4 on: May 06, 2010, 06:38:32 PM »
If your ECM has no aftermarket tune, then a reflash by the dealer with all the latest TSB's may fix the issue.
Offline Aspenrose
« Reply #5 on: May 06, 2010, 07:07:36 PM »
It does, and on the way home it decided to start working again. So for the moment all is well, but I'm thinking it will flake out again, prolly sooner than later.
« Reply #6 on: May 06, 2010, 09:32:37 PM »
Here's several options.
The BCM controls power to the radio - Use a #7mm socket and ratchet and pull the BCM connector off and reinstall it.  That will reset the pins that send power to radio.
Also.
The radio actually can be flashed by a dealer.  Take it in for a new load.  When ever you replace the radio, they have to flash it with a VIN.
Offline Aspenrose
« Reply #7 on: May 07, 2010, 12:13:13 PM »
Also.
Good to know about the flash thing, I'll be replacing mine sooner than later with the SKY USB radio, no more CDs in the car, more room for a buncha flash drives  :lol:
